Question about Iomega (33090) 250 GB Hard Drive
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
  • millermoto Apr 08, 2009
    You want to make sure you get the 4-pin version of the DA-30C03 (p/n 31426900).
    I have noticed that there are different part numbers for the DA-30C0 and I think the only difference is the configuration of the pins on the plug. The Iomega 250GB external hard drive I have also uses the DA-30C03 with p/n 31426900. It has the same pin configuration as an s-video cable.
    I found another model DA-30C03 at a Goodwill store for $3.99 and picked up an s-video there for another dollar. I'm getting ready to do a bit of hacking on the plug and will report back if I toast the drive.
  • 25 Answers
This Iomega DA-30C03 power adapters. It has two different version. One require 12V 5V 5 pins power supply, and another need 12V 5V 4pins connectors. Under same model number, but, different version. you can find those two version adapter as below link: http://www.powerpayless.com/iomega-da-30c03-ac-dc-power-adapter-din-4pin-equiv.html
http://www.powerpayless.com/iomega-da-30c03-30941702-ac-dc-power-adapter-with-5pin-equiv.html
Posted on Aug 01, 2011
I have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Posted on Nov 25, 2008
  • tamisra Sep 27, 2010
    i have one available
    see pic :http://img697.imageshack.us/img697/286/p...
    if you interested contact me
    tamisra@gmail.com
    Problem Solver:
  • 5 Answers
You can find a compatible power adapter for DA-30C03 / 31426900 here:
http://www.ep-mediastore-ab.de/netzteil-5v12v-kompiomega-31426900-p-80445.html
hope it helps someone
Posted on Oct 22, 2010
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I have an iomega portable hard drive USB 2.0 called eGo. I have been using it with my Macbook. Since yesterday my computer does not recognize my eGo. I have tried to change the USB ports, have restarted...
* the USB cable
* the power-adapter
Dec 11, 2010 | Iomega eGo Portable Hard drive 500 GB ...
When i plug in my iomega 500gb portable into my laptop its not showing up in my computer and it's making a beeping sound aswell
* the USB cable
* the power-adapter
Nov 28, 2010 | Iomega 34611 500 GB USB Hard Drive
My Iomega (p/n 31706500R) 500GB USB isn't working. When I turn it on the blue light comes on for a second. I can hear / feel it working but then the light goes off (it is still whirring inside). The...
* the USB cable
* the power-adapter
Nov 17, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Terabyte iomega hard drive, the two lights are flashing red, fan not operating, no access via My Computer.
* the USB cable
* the power-adapter
Nov 08, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have iomega zip drive with no power adapter it is scsi scuzzy cabled 12 pin model z100P2 where do i find pwr cord
look on ebay for a power cord for it. ans scsi is "scuzzy" it just sounds like us tech guys are saying "scuzzy"
Jun 04, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Broken pin on my Iomega power suupply P/N 31426900. Does not match four pin pictures on products
you can buy this here:
<a href="http://www.ep-mediastore-ab.de/netzteil-5v12v-kompiomega-31426900-p-80445.html">http://www.ep-mediastore-ab.de/netzteil-5v12v-kompiomega-31426900-p-80445.html</a>
best regards
k
Dec 04, 2009 | Iomega (33090) 250 GB Hard Drive
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
1,473 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
