With a HomeLink card installed in your PC, connect your PC to a phone jack using a standard phone cable. Using another standard phone cable, connect the card's other phone cable port to connect to your second PC. Continue to connect up to twenty-five PCs in this way on one chain. If you want to use your telephone, modem, or fax machine, add a two-way splitter to your wall?s phone jack or connect the device to the empty phone jack in the last card at the end of your daisy chain.
Daisy-chaining your HomeLink PCs and peripherals can create a simple network that acts in the same way an Ethernet network acts on your PC's desktop. In a HomeLink network, data passes into one side of a port, and continues out from the port?s other side. You can string up to 25 PCs on a single HomeLink network, provided that the entire length of cable does not exceed 150 meters (500 feet).
HomeLink networks can send data through existing telephone lines without disrupting your telephone service. If you have PCs on two different floors of your house, plug one of the downstairs PCs into the phone jack in the wall, and you're able to network your PCs upstairs without running excessive amounts of extra cable.
router seems to be working fine but dont seem to recognoise de modem.i cant go on line with it, it...
(More)
router seems to be working fine but dont seem to recognoise de modem.i cant go on line with it, it seems to conect and is receeving data
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not...
(More)
I'm trying to set up two computers with DSL,but when we the tech tried to walk me thru it, did not work. Once the router was hooked up, couldn't get online. The tech is saying the router is faulty, but it worked just fine with Comcast. Switching from Comcast because cost keeps going up and going up again next year. Is D-Link compatible with DSL?
Hi, i have an actiontec GT704-WG router, and my laptop connects to it through wireless. i've been...
(More)
Hi, i have an actiontec GT704-WG router, and my laptop connects to it through wireless. i've been using Emule but its extremely slow, so i figure i've got a low ID. Then I've turned on the UPNP, and changed the firewall setting. But i still cant pass the port test. so how can i get a highID? Thank you !!!!
