Question about Sony STR-DB930 Receiver
Volume control turns around - front part of the shaft snapped
The front of the volume potentiometer shaft (aluminum) accommodating the LED had snapped off the back part which is riveted to the turning wheel by two tiny rivets. To fix this will I have to look for the whole volume PCB (Sony part 1-673-362-11) or have I got any other alternatives?
Regards
geniusgeorge@yahoo.com
    Genius:
  • Sony Master
  • 1,673 Answers
Unfortunately you will need to replace the original part to service your receiver.
Jerry G.
Posted on Jan 08, 2009
I04 Lincoln Navigator. Front differential pass seal leak. remove the drive shaft and unbolt the flange. the inner flange does not have a bolt to access the seal and bearing. How is the seal accessed?
If I understand you correctly the drive shaft you took out is actually a CV axle. The inner axle shaft goes into the diff. That is held in with a snap ring in the diff. It might not come out easy, sometimes they do, use a pry bar to pop it out. Be careful not to break or damage the aluminum housing. There have been times where I had to use a strong air hammer to beat on the back side of that flange to get the axle shaft out... It's sort of like taking a CV axle out of a front wheel drive car.
Oct 27, 2017 | Lincoln Cars & Trucks
Volume control on teac crh250
Make sure the volume knob is tightened to the volume potentiometer shaft via the set screw on the knob itself.
Jun 12, 2016 | Teac Audio Players & Recorders
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
Need to replace volume potentiometer on BC-60 XLT scanner
make a trip to radio shack for a replacement volume control..
Feb 02, 2014 | Uniden Radio Communications
Ge cb radio
Possibly a bad volume/on/off volume potentiometer. Try using canned air around the volume/on/off knob to remove any debris down along the shaft. If this does not help, your unit may need repair. Do not use any chemicals, cleaners or solvents on the shaft, only use air.
Clean your internal battery contacts on the batteries and the radio with a pencil eraser to assure good connection. If you are using rechargeable batteries, try charging the batteries again.
Best regards.
Sep 28, 2013 | GE Hand Held Cb 40 Channel Model 3-5980a...
Removing front wheel well arch cover volvo xc 90
The fasteners are available on line if you can't find them.
Jun 13, 2012 | Cars & Trucks
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
For a Shwinn Joyrider PR150 double kids trailer Bent connecting shaft for front wheel to stroller, within front wheel assembly. I disassembled the front wheel assembly and straightened the bent...
Depending on how old it is, I would send it back on warranty. Do not keep bending it or it will break when you bend it, or worse, while in use. It might just be better to get a new, more durable stroller all together.
Jul 15, 2011 | Schwinn Joyrider Bike Trailer Red/Black
I want to take the radio apart, but the antenna and turn on/off knob will not come off. How does the antenna and turn on/off knob come off on a T7400, T7450
Antenna is fixed and attached to the housing. The front and back housings must be first removed to get to it. The volume knob will pull straight up and off the volume potentiometer shaft. This is risky because the small clip which holds the knob in place usually gets stuck on the shaft and then you run the chance of not getting the knob to stay back on the radio.
Best regards.
Apr 07, 2011 | Motorola Talkabout T7400R (2 Pack) (7...
Need a part # for the volume potentiometer. It has been cleaned several times already & the shaft is loose/wobbles & sound is staticy/comes & goes as volume is raised & lowered &/or...
There are many configurations for volume potentiometers - If you remove yours, you can get the serial number off it and go to a local electronics supply store ( or website , like www.radioshack.com) you should be able to purchase the right one. If the shaft is wobbling, you may be able to tighten up the casing by bending the tabs on the back of the casing - make sure you're squeezing the casing closed with the shaft in the proper location. If you have talent ( this part is really challenging for me ) you can straighten out those tabs, disassemble the switch, clean the contacts with a pencil eraser, regrease with dielectric grease and re - assemble. Personally I would just buy another - much easier!!
Good luck either way!!
Nov 23, 2010 | Audio Players & Recorders
Sony STR-DB930 Receiver Logo
201 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
