Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Help what is an enclosure re seagate frree agent problem?
    Scholar:
  • 55 Answers
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Posted on Sep 12, 2008
What are the parts called - Data connection plug broke off inside freeagent external drive
You can try installing the drive into a new enclosure as long as the internal circuitry of the free agent did not alter the formatting of the hard drive. IE in a buffalo external drive the internal circuitry creates a linux partition on the hard drive that cannot be read by windows directly.
Jun 29, 2013 | Seagate FreeAgent Computers & Internet
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Jul 07, 2011 | Seagate Free Agent Go Small 12 GB USB...
I have a Segate Free Agent Desk 1TB External HDD. Today when I plugged it in the power supply, the LED light keeps on blinking. The Drive is not getting detected by my Laptop. I tried it on my Desktop, But...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 30, 2010 | Seagate FreeAgent Pro 1TB External USB...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Hello, I just bought a Seagate Free Agent Go 1
* the USB cable
* the power-adapter
Nov 20, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
I have a Seagate Free Agent M Series 750 GB external hard drive. In using it yesterday, I connected to my computer and it was fine. After about 20 minutes the unit shut itself off and now has no power to...
First step, check the power cord, if you have a multi meter, set it to the 20v range DC and test the AC adapter for voltage.
If it is dead you may be able to get a replacement but it's likely cheaper to move the drive into a new enclosure(see the next step)
Stop in at your local computer store, ask the techs to sell you a SATA HDD enclosure and either move the drive into it for you, or if your feeling handy take it home and give it a try yourself(this WILL void Seagates warranty)
Once the drive is in the new enclosure, hook it up to the computer and see if it works, if so you're done. If not, send it to a pro for data recovery. In North America I always recommend Armot-IT Data Recovery(in FixYa Database), if you're in another region add a comment here and I will make an appropriate recommendation.
Hope this helps FixYa,
Chris
May 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need a power cable
A user on the Seagate forums indicates that his uses a 12V 2A DC power supply. I would suggest, however, that you remove the hard drive from that enclosure and place the drive either inside your PC or inside another enclosure.
If all else fails, contact Seagate: 1-800-SEAGATE
Let me know if this helps!
Apr 05, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Problem
Hi Ryan,
I decided that retrieving my data was more important that the seagate warranty and i was not prepared to send the free agent overseas with the data still on it so i removed the hard drive from the freeagent case (case now stuffed) and put the hard drive in an "off the self" hard drive enclosure". All my data was there. It is still working fine. Two big lessons for me - moving files from my lap top to the external drive is not back up and external hard drives can be fragile, best not move them around like a library book. From my low tech view the circuit board on the freeagents is flawed.
Regards,
TMV NZ
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
191 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
