Question about Sony VAIO PCV-J200 PC Desktop
Power supply all the cables are connected.if the psu was dead, would it still be blinking wen connected to the mains?should i replace the cables again?
  • johnderrick Sep 08, 2008
    finally managed to get it on.i disconnected the power supply to the motherboard,plugged in the psu to the mains,reconnected the motherboard power supply with the psu still on and voila!!so how do i fix this problem beacause when i shut down and boot,it starts blinking again.
  • 118 Answers
It is blinking because its drawing power still. The problem is putting it out. a SIMPLE CHECK TO SEE IF ITS DEAD IS DOESYOUR CD DRIVE OPEN? IF IT DOES LEMME KNOW IF IT DOESNT ITS DEAD
sorry boutthe caps
Posted on Sep 08, 2008
  • Benjamin  Bielski
    Benjamin Bielski Sep 09, 2008
    That helps but i need to know, does your cd drive open?
What is a PSU?
psu or PSU is an abbreviation standing for Power Supply Unit. This is often a device (box) which converts your mains supply (input) into the voltages (with currents) which are correct for your device (eg your printer). This may be inside the case (eg in a computer) where you cannot see it, and you just plug in the mains lead to the device, or an external box which has two (or more) cables or connections to/from it, one or more of which is connected to your devise (eg a laptop computer). Printers may have either depending on the model. Every model of device has its own model of PSU (or family of suitable PSUs). Just any PSU will not do and might damage your device
May 20, 2014 | HP Deskjet F300 series
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
Standby blinking green button went off and now cannot turn on. cord connection ok and eveything unplugged that might interfere
I guess your power supply died. try to disable the power supply and enable it again (switch behind the tower) otherwise you should get it checked out by a professional.
Mar 02, 2011 | Dell Dimension 4700C PC Desktop
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
No power PC is dead tried a spare power supply and PC works.. Green led on rear of power supply blinks all the time.when disconnecting 110v ac plug light then dims still blinks but slower then goes...
the original psu is dead toss it. the one you are using is not powerfull enough to run the pc. check the old opne for how many watts. then check the new one. i bet the new one has fewer. so to solve problem get a psu with the same or more watts than the old dead one.
Jun 20, 2010 | Bestec (ATX100-5) (ATX1005B) Power Supply
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns;
Feb 19, 2010 | Computers & Internet
HP won't power on at all~PSU light blinking, then solid, then off
Dead short on the machine causing the power supply to go into shutdown (Fold Back Protection)
Remove all of the connectors coming from the power supply (Label them so that you know here they go back to on the Motherboard and the DVD etc (Including the processor fan one)
Place all of them back one at a time starting with the main one if the led stays on then plug in another till you locate the short.
If the led dies when you plug in the main MB connector then you are in deep brown stuff
All you can do then is to remove the Ram and any other unpluggable device to see if that is the cause
Jul 05, 2009 | HP PAVILION A6230N DESKTOP PC
The cable light on my modem keeps blinking for long periods of time and won't let me axcess the internet
This would indicate a problem with the cable connection, modem,or your ISP
Try replace the cable that comes from the RF connector to the wall outlet (use a good quality one)
Also if you have ANY form of splitter / divider in that line that was not supplied by your ISP for splitting a modem signal then remove it.
Check the output of the power supply for the modem if the psu is faulty then replace with a universal adaptor that can supply both the correct voltage and current (they are usually listed on the original psu eg. 9V 500mA)
DO NOT use any psu that cannot meet those two numbers a 300mA supply will not be suitable but one that is slightly higher eg. 650mA will.
If you still have problems then contact your ISP for a replacement.
If this information was of any use please click below
May 16, 2009 | Toshiba PCX2600 (c40054) Modem
Dead psu
Apply a new PSU, the question is is it worth it to you? A psu is rather expensive to replace I would not try repairing it if I were you.
Apr 22, 2009 | Televison & Video
Psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Sony VAIO PCV-J200 PC Desktop Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
