Question about Linksys WRT51AB Wireless Router
Static IP on machine, now can't access web sites
I assigned a static IP address to my computer and now I can not access the internet, what can I do?
    Novelist:
  • 196 Answers
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Posted on Feb 16, 2006
SOURCE:
What is the ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.
There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address.
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Jul 24, 2013 | Computers & Internet
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
Try to reset WRE54G
Resetting the Range Expander to Factory Default
The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
NOTE: The default IP address of a range expander is 192.168.1.240.
After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
Checking Physical Connections
Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
Checking LEDs on the Network Adapter
Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
Assigning the Computer a Static IP Address
For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
Checking the Computer's Connectivity to the Range Expander
For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
For instructions on how to restore the range expander to factory default, click here.
If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
Connecting Wirelessly to your Range Expander
NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
Step 1:
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
4146-005.pngStep 2:
Click Site Survey then select the SSID of your wireless range expander and click Connect.
NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
4146-007.pngChecking the Computer's Connectivity to the Range Expander
NOTE: If you're using Windows 98 or Windows ME, click here.
If you're using a Mac computer, click here.
Windows 2000/XP
Step 1:
Click Start, then click Run.
Step 2:
When the Run window appears, in the Open field type "cmd", then click OK.
3984-003.pngStep 3:
When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
Step 4:
See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Can not access my ip address in order to change NAT settings
Hi Brengolfter3,
My guess is, the IP to your router is still 192.168.x.x. Only way you are going to be able to get to the router, is to set your machine to a static IP, and then try to get to the router.
This site tells you how set it to static, http://corz.org/comms/hardware/router/static.ip.address.php
The IP you listed is assigned to Easton Utilites, so I have asume it is your internet IP. You might want to check the Xbox troubleshooting for the Xbox, so you don't have to disable your Nat, which is a firewall, by default. Good Luck!
Jan 05, 2008 | Computers & Internet
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Linksys WRT51AB Wireless Router Logo
237 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
