Question about GE 25.1 cu. ft. / 711 liter Chest Freezer FCM25RMWW
Freezer will not turn on
A couple months ago my landlord had to replace the curcuit breaker my freezer was plugged into. wen I plugged it back in t he light came back on. But it would not freeze. I put it on my covered porch till I could get to it. Now it will not turn on at all. Not even the light.
  • preciousgift Sep 08, 2008
    a couple months ago my landlord had to replace the curcuit breaker my freezer was plugged into. wen I plugged it back in t he light came back on. But it would not freeze. I put it on my covered porch till I could get to it. Now it will not turn on at all. Not even the light.
  • Anonymous Sep 12, 2008
    I defrosted my GE 20 cu ft freezer, plugged it back in and it tripped the GFI it was on so I reset it and turned the breaker back on. Now the light is on in the freezer but it won't run.
2 Suggested Answers
  • 226 Answers
SOURCE: my brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Posted on Apr 29, 2009
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Our dog chewed the cable for the plug on our freezer ..repaired the cable and changed the plug but still not working
Your breaker tripped as he chewed it . Turn off the breaker then back on . It should be fine.
Feb 21, 2013 | Freezers
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
My brand new freezer wont freeze
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Hotpoint 25.3 cu. ft. not cooling
When the freon as been recharged, did the dryer been replaced?
Nov 25, 2007 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
GE 25.1 cu. ft. / 711 liter Chest Freezer FCM25RMWW Logo
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
