Question about Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl-700 Hi My on/off switch has fell out of the machine i have put it back in a few times and pressed it and it worked . however now i press it but unless i hold it in it will not stay on any ideas
I looked on the net found the number of the dishwasher maker called them they said it needed a new on/off switch which i bought and fitted in a few mins £9.99 4 wires
Posted on Sep 09, 2008
Upper arm spray fell off my Indesit dishwasher. How do I put it back on?
Usually, there is a small stainless steel sc rew with a knurled edge. It fixes through the central boss of the spray bar. You should find it in the bottom of the machine in the strainer, or hiding in the bottom somewhere.
Jun 09, 2016 | Indesit Dishwashers
Hi i have a 98 honda accord lx and i wanted to know wether it was my trammy or the clutch because when ever i do a rolling stop or if i had jus finished backing up nd as soon as i put it in drive and press...
I had the same problem on a 1998. The computer controlled mixture at idle is not working right, and idle is dipping below 700 rpm. The culprit was a dirty throttle body intake. This tends to foul the plugs as well, after a few minutes of idling, so i would recommend changing the plugs after you have the system cleaned. The problem is intermittent because at high engine speed, say 3000 rpm, the plugs clear up and work normally.
Sep 29, 2010 | 1998 Honda Accord
Washing machine wont stop it has been going from last night
turn off at wall and unplug .after a few minute's plug back in and try and reset machine by putting dial on one of the dots switch on the red light should flash 3 times and switch off .I this works try and put machine on again a spin only will do if the same problem returns you probable need a new pc board . cost about £55to 90pounds before fitting .
Feb 11, 2010 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
Jan 24, 2009 | Indesit W 123 Front Load Washer
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Start button not working...can't get machine to start
The micro switch is bad. I had the same problem cleaned the switch a few time (nd bought some time) but in the end I moved a switch from a cycle we did not use to the start position. Cost was nothing but my time (must have skills in soldering PCB assy). Worked fine since, almost a year now. However I have had several unrelated problems and would thing twice before putting any major money into this unit. In the 3 years I;'ve had this unit I've fixed the switch, installed a new pump assy and put in 2 thermal switches (unit appears dead when they go bad). I've done all this myself and the bills would be between $700 nad $1,000 to call service.
Oct 21, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Using a washerdryer
Hi what I would advise you to do is check to see if the blower is working take the top off the machine and switch on the dryer and listen for the motor working if it is then switch it back off and feel the heater housing to see if it is warm if not the reset on the stat may need to be press if this is still not the fault check fan on the heater motor could be broken and the motor is just spining
Jul 18, 2008 | Indesit Washing Machines
Showing dNE0
We had the same problem and got this from Indesit consumer line - it works!!!!!
1. press and hold the reset button for about 5 seconds.
2. press and hold - start/reset button
on/off switch and
the left function button ALL AT THE SAME TIME
keep holding until D OFF appears - this took about 15 seconds before it did it for us.
Feb 19, 2008 | Indesit W 123 Front Load Washer
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Indesit 24 in. IDL700 Built-In Dishwasher Logo
198 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
