Question about Archos 605 Digital Media Player
CANNOT VIEW ON TV SCREEN
I've put all the wires in the right sockets but cannot get the output to play on my TV screen or even show the menu screens.
  • Anonymous Oct 02, 2008
    Same problem.....using a minidock, connected the wires right (3 coloured) and NOTHING....tried on 3 tvs all same. do I need an S video (i.e. 4th connection?) . Mikey
  • 4 Answers
You may have you going into the Archos setting and select the video output to use.
Posted on Dec 16, 2008
Just click the the button on the top of the Archos beside the power button to switch between tv and screen modes.
Posted on Dec 02, 2008
How do I move from A1 to picture?
Make sure you know which input you have used on the tv, play a video and use your tv remote to select the right socket.
Your tv remote should have a button called source or input or look in the main menu, it should all be easily read from the screen
Oct 14, 2014 | Televison & Video
The picture is outside the edges of the TV
It's probably an issue of the "Aspect" or the "Screen Mode" you're in. I'm no TV repair expert, but if you look in your Main Menu for "Screen Mode" or even your remote might have a button labeled "Asp" or "Aspect" or "Mode"....or even "Wide" (which when pressed repeatedly will cycle through the most common 4 screen modes = Wide, Screen Fit, Zoom, 4:3.) The last one refers to the ratio aspect, but depending on your TV, they could be named differently.
Given your description, it seems you're in "Zoom" mode, since it's cutting off the edges of the picture. Put it on a station like CNN, which has a streaming ticker at the bottom and cycle through the options you have until you find the one you prefer. (Note: you should also be able to set this in your Main Menu somewhere as your preferred view, but some shows and movies might come through as full screen or 'Letterbox' regardless of your preference.
One final observation I've found on several units is that the remote button that's in the bottom right-hand corner (which may not be labeled as such) is the default location for your aspect selections. Push it and see what happens.
Jul 22, 2012 | Philips 47PFL7403D 47 in. LCD TV
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Flashing (ghosting) on screen when playing DVD's or VCR tapes
I've had a similar problem, It was not the TV or the DVD player but the SCART junction box (a separate unit that automatically sent the live input to the output SCART socket, to fix I just uses a spare empty input socket.
if you don't have one of these units try with a different SCART socket or AV input also try replacing the leads between the player and TV.
Nov 10, 2008 | Digimate DGL32 32 in. LCD Television
Cannot connect my home cinema system to play my tv sound
what system does it have aux input on screen showing right input u pluged rca cables from tv rca outs to sterios ins right or cable box outs to sterio ins red white rca cables right make sure tvs output sound is on in menu thx nick
Oct 06, 2008 | Samsung Televison & Video
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
DVD's will no longer play in color
We had the identical problem, which was solved by changing the input channel on our Panasonic plasma screen. This was not obvious and we needed help from the person who installed the system. The input channel had changed automatically!
Feb 07, 2007 | Sony DAV-S300 System
Archos 605 Digital Media Player Logo
37 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
