Question about Sony NW-E105 MP3 Player
I have a sony NW-E105PSBLU and the headphone jack is loose and i can only hear sound in the right ear unless i hold it in or tape it into position with duct tape (which does not work for long !). do you know how i can dismantle it and see if it needs some solder to fix it up ? i really like it and do not want to replace if i can help it. thanks. Todd in Welcome, NC
5 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Ear Jack
Theres a good posibility that the solder connections are the only thinbg wrong with the connections BUT theres a possibility that the Printed curcuit board its self is a flex board and that the flex connections are torn. If thats the case you probably wont be able to fix the unit. If you can open the unit then you can look at the connections and see if its just plain old solder connections?? Good Luck
Posted on Apr 23, 2006
SOURCE: loose earphone Jack on sony NW s705f
Hiya,
If you remove the "hold" switch from the back of the unit, you'll discover a screw. Remove the screw and gently life the metal off cover off, it's might appear stuck but this is ok, it's held in place with a bit of double sided tape. Once inside there are two more screws... and to remove the PCB, there's another few screws.. Have fun!
However, I'm thinking when you say loose, are you referring to the physical socket? Because inside the player the socket isn't mounted directly to the PCB, instead it's mounted to a super thin plastic with copper-like contacts which in attaches to the main-board. The actual socket is designed to be slightly loose turns this puts less stress on the PCB and it's held in place buy the track controller/collar...
My advice, if it works don't dismantle it..
Posted on Jan 10, 2008
longgee
  • 322 Answers
SOURCE: sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
Posted on May 03, 2009
samanthaj08
  • 570 Answers
SOURCE: My Ipod Nano only has sound in one ear.
Within the jack, there is a very delicate balance. The same thing happened to the auxiliary jack in my car. Since it is broken, you'll need to either see if you're eligible for an Apple warranty replacement or repair, see if a local electronics place can fix it at a decent price, or spring for a replacement.
Posted on Oct 02, 2009
Testimonial: "awesome"
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Tip
How to connect your guitar amplifier to your computer
  1. Plug in the amplifier
  2. Turn it on
  4. Plug it into the amplifier
  7. Take the remaining amplifier jack end and unscrew the bottom of it from its housing
  8. Take the remaining headphone jack and hold it to the wires inside the amp jack
  9. Turn some sound on on your computer
  10. Find the best position with the most clearly defined sound and tape the headphone jack in place with electrical tape.
on Apr 12, 2010 | Audio Players & Recorders
Need headphones for sony mp3 player
You can get ear phones for MP3 players with a 3.5mm from computer or music shops or on the Internet.
Jul 12, 2012 | Sony NW-A1000 MP3 Player
One of my ear phones is not working
Check the cable at both ends, at the connection to the headphones and the jack. Try jiggling it around a bit while you have music playing to see if you have a loose connection. If this is the problem a temporary fix is to tape the cable up in the position where the wires inside are connected.
Mar 28, 2011 | Sony Audio Players & Recorders
I am only receiving sound out of one ear from my mp3
Open up the player and look at the headphone jack, there may be a loose conneciton that needs to be re-soldered in or the jack itself is faulty and will need to be replaced. You may be able to get one from etech.com
Sep 22, 2009 | Sony NW-HD5 MP3 Player
My samsungs Yp-p2 headphone in-put is borken. It wont let me hear the music thats playing on the mp4 unless i hold the headphone jack in a certain position i the head phone i-put? PLz help
Yo. Your guys problem is the headphone jack. Once it cracks, this situation happens. It's really easy to crack because the headphone jack part is alone in the YP P2. You just need to go to a samsung shop and get this repaired. Not expensive at all. haha Oh and when you get it fixed, tell them to put a plastic part beside it to try preventing it from happening.
May 03, 2009 | Samsung YP-P2 Digital Media Player
Ear jack in Iriver h10 doesn't work correctly
I bought a used unit from ebay with the same problem (discovered later) and had to buy another as-is player, open it up, and replace the defective headphone jack module on the first player.
see this forum for directions to open player: forum
plan b - sell the unit as-is on ebay and put your profits toward a 20gb refurb for $30-60 (from sellers like metromania)
Feb 09, 2009 | iRiver H10 MP3 Player
Cant hear out of right ear piece
The usual cause for that is that the headphone jack is loose or the connectors are loose inside the unit and therefore not keeping complete contact with the headphone piece. It can be repaired but would probably be cheaper to get a new MP3 if that is the sansa one.
Feb 03, 2009 | Insignia Sport MP3 Player
The sound is intermittent on my Sony NW-E507 Network Walkman.
this is because your mp3 headphone jack is loose.go to a repair shop and they will fix it 4 cheap$$
Oct 26, 2007 | Sony NW-E507 MP3 Player
Loose earphone Jack on sony mp3 player NW s705f
you will need a very small soldering iron (pencil) and solder and solder the jack back on the board
· http://www.noboundrees.com/micro_fix/
· http://www.pcpages.com/thebishop/nomadfix/
· http://www.instructables.com/id/Zen-Micro-Headphone-Jack-Fix/
Oct 17, 2007 | Creative Labs Zen Micro MP3 Player
Sony NW-E105 MP3 Player Logo
48 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
