Question about Sony VAIO PCV-J200 PC Desktop
Power supply i have a power supply problem.about two days ago,my pc refused to go on.when plugged into power, the supply light blinks.is there a problem with my power supply unit?
  • johnderrick Sep 08, 2008
    i changed the power supply cable from the outlet to the psu, and it worked for a day.once i shut down, it didnt come on. the light at the back on the psu keeps on blinking each time i plug it in.
  • 118 Answers
Eah todd is right. Unless your main Plug from the PSU to the Motherboard is disconnected. But the chances opf that are slimmer im afraid.
Posted on Sep 08, 2008
My Dell XPS 200 will not turn on.
Have you checked to see if your power supply is still good, or the power supply connection to the motherboard is good?
Sep 14, 2012 | Dell XPS 200 PC Desktop
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
Tv goes on and off on it's own. The red light constantly blinks and now the tv refuses to go on. This tv is fairly new. I am frustrated.
Power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement
Jun 11, 2011 | LG 32LG30 32 in. LCD HDTV
I plug power cord and nothing happen no light is blink means dump , i shutdown 2 days back pls advvise what to do'??
Sounds like a bad power supply or possibly bad mother board. Make sure the fan in the power supply comes on when you plug it in. Also if, you are game, look inside the PC and make sure the power supply is plugged into the mother board and not loose.
Hope this helps rate if it does please.
Sep 30, 2010 | Dell OptiPlex GX270 PC Desktop
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Pc not turning on led light blinking
check if there is a switch on the back of your power supply if there is try turning off then on again .still no power replace you power supply
Jun 26, 2009 | HP Pavilion A210N (DF210A#ABA) PC Desktop
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Sony VAIO PCV-J200 PC Desktop Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
