Question about Acer Aspire 3680 Laptop
Pressing F5 When i press F5, pops a screen that says something is inconsistent and need to do a scan. After scan, the same thing happens and there is no option to choose safe mode. it doesnt sense my recovery cd too. is there any other solution to at least retrieve my stuff? many thanks Regards
    President:
  • 2,961 Answers
It sounds as if your hard drive has some bad clusters or errors, if you wish to repair your system, when the notebook is turned on press F2 or Del, i think Del to enter the bios and make the cdrom the first boot device otherwise the disc will not be seen.
Save the settings and exit for a reboot and then insert your cd before it starts to boot up again and it should halt on the boot and say press enter to boot from cd, do so and then depending on the cd you have should say press 'R' for repair or F8 or Enter to install windows, if you have docs and stuff still on your notebook, choose 'R' as this will not delete anything, just repair the system files, and then follow the set up instructions.
Posted on Sep 10, 2008
Acer laptop screen is dark an will not brighton l
I would like you to try 2 things:
1. Press and hold the blue Fn key then press the right arrow key a few times and see if it gets brighter. If that doesn't work try #2
2. Press and hold the blue FN key then press F5 or F6 not sure which one changes your screen. If it seems to mess something up it's ok. Just press the same combo that messed it up once or twice and it will go back to normal.
Please comment and let me know if it worked! :)
Apr 10, 2013 | Acer Aspire 3690-2196 Notebook
ComI have connected my laptop to Sansui 32 inch LCD through VGA cable but the i am not getting the notebook screen displayed on tv continuously. the screen gets displayed for a second and goes off, it is...
You may need to enable the notebook VGA output. They can switch between notebook only, notebook + VGA or VGA only. You usually press the "fn" key and one of the Function keys at the same time. On my laptop, I press "Fn" and "F5". Please note that it can take some seconds for the switching to be completed so press them together once and then wait 10 seconds to see if it does what you want. (remember it may be something other than F5, look for a picture of a monitor or a square symbol).
Feb 06, 2011 | Sansui HDLCD3210 32 in. LCD TV
The display is black
If you can still hear everything else working try adjusting the brightness, there should be keys to do this on the keyboard, if it has no effect i suspect your lcd back light has gone.
Jan 20, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
Monitor won't work after computer starts up
You need to be sure that your unit is unplugged first before connecting PC. You will see all of your startup settings on your PC. In order to view the desktop on your monitor (does not work on Mac OS) press CTRL+F5. Anoption box will appear and by holding CTRL button and pressing F5 you will see your options change.
Aug 07, 2009 | Samsung ToC T220HD 22 in. LCD HDTV Monitor
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have pressed Fn and F5 on my easynote laptop now the LCD screen has gone wierd. How do I reverse this?
fn + F5 changes output mode
its 3 way toggle switch
1. laptop screen only
2. secondary display unit only\
3. mirror on both display units
press Fn+f5 keys again to revert to normal mode
Apr 04, 2009 | Computers & Internet
My laptop has a blue then black screen after start-up
Press F8 when you laptop starts. Go to safe mode. Scan and remove virus in safemode. Try and restart your laptop when completed.
Jan 09, 2009 | HP Pavilion dv9000z Notebook
Cobra-sr900 reception
Press E after the Channel # instead of manuel.
May 27, 2008 | Audio Players & Recorders
Acer Aspire 3680 Laptop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
