Question about Brother MFC 420CN All-In-One InkJet Printer
Keeps saying low on ink
This is New and the first cartridges i changed after a couple copys said low on one color then print another says low on another . took back to where i bought and they charged to fix and would tell me nothig but not to leave on I DON'T LEAVE ON !. now have made 8 or 10 copys ( Black & White ) and it is telling me low on yellow , so i removed and looked at and put back now it says out of black . ALL ARE NEW . "AGAIN " What is going on with this thing ??
  • 659 Answers
Well this sound similar to the problem I had a first with mine. Once I replaced one the next would be out and so on. but some where not out at all. I find when changing the carts remove them from the machine turn the computer off so no connection to the computer and remove the power from the wall. Replace them and do not plug into the computer and run a test print. My software on my computer produced a low ink warning which obviously its not so I pulled them out again used a Q-Tip Cleaned up the contacts on the ink carts and in the unit that I could reach.
The thing that I always worry about since working for HP's AIO Tech support department their ink carts had experation dates and would constantly fail.
Send the machine through all the cleaning processes and alignments ect.
and if the ink that was replaced with different ink than that which was origionally placed in the printer from Brother this might continue to produce these error.
so after messing around with my unit turning it on and off and doing a bunch of printing it finally leveled itself off since I never leave my printer on all the time.
Check and make sure all your carts are in properly.
give that a try and if that doesn't work let me know and I will post a secoundary solution for you.
Posted on Sep 16, 2008
Why when press color copy the non color not print are not being printed
If your question means that you are not getting "nice" color copy ... it may be possible that your (color) ink is running low or empty. For instance, if your black ink is low or empty, you will not get the black colors printed ...
So, check to see if your ink cartridges are running low or empty. And if so, see if a (new) replacement cartridge will give you the same result.
Aug 16, 2014 | Office Equipment & Supplies
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
Aug 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
The printer keeps doing the alignment and saying that there is a problem. My color ink cartridge is low but I would still like to print with black ink. I don't know if the color cartridge being low affects...
Replace your color cartridge and power printer on. The color cartridge is probably empty (even though there might be a little ink left in it). Many inkjet printers require the color cartridge for composite black even if you are not printing in color.
Jun 16, 2010 | Dell 926 All-In-One InkJet Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
