Question about Linksys (WRT54GC) Router
Information About Management Mode for Firmware Recovery
What is Management Mode? How do I recover my router if something goes wrong and I cannot access the Setup pages to upgrade firmware?
    Novelist:
  • 196 Answers
What is Management Mode? If you encounter an irrecoverable condition with the WRT54G v5, you can use Management Mode to recover the router by uploading a new firmware image. In Management Mode, the router will have just enough functionality to load a newer firmware. You should be able to recover the router is most situations. When will the WRT54G v5 enter Management Mode? The WRT54G v5 will enter Management Mode when: * The router's firmware is corrupt (for example, when the router's Power light is blinking), OR * When the router has been reset incorrectly using the following steps: 1. Unplug the power cord. 2. Press and hold the Reset button. 3. Plug power cord back in (Reset button still held in). 4. Wait about 5-10 seconds. How do I get out of Management Mode? * To get out of Management Mode, simply unplug the power cord from the back or router for ten (10) seconds and plug the power cord back in (without using the Reset button). If the router's firmware is complete and without error, the router will start up normally. If the above does not work, try: * Download a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. After unzipping and extracting the firmware file, click on the Browse button from the Management Mode page, select the firmware file, and upgrade the firmware. After this, Reset the router normally (by holding in the Reset button for 10 seconds) and the router should exit Management Mode. How do I enter Management Mode manually to recover my router? NOTES: * The PC that will be used for the recovery MUST be connected to the router via a hardwired Ethernet cable and not a wirelessly connected computer. * Be sure that you have a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. * In most cases, the router will be able to provide an IP address via DHCP when in Management Mode. If your PC does not automatically receive an IP address from the router, you will have to set up a static IP address for the upgrade. See Answer ID 534 for more information. * When the router is forced into Management Mode, the Power light will blink. 1. Unplug the power cord from the back of the router. 2. Hold down the Reset button. 3. While holding down the Reset button, plug back in the power cord to the router. 4. Continue to hold the Reset button for five (5) seconds. After five (5) seconds, release the button. 5. Wait for about one (1) minute. Then, on a computer connected to the router, launch a web browser (for example, Internet Explorer or Mozilla Firefox). 6. Type in the router's IP address of http://192.168.1.1 into the Address field and press the [Enter] key. 7. The Management Mode - Firmware Upgrade interface should appear. NOTE: If you accidentally enter into Management Mode, you can exit by simply unplugging the power cord from the router and by plugging it back in. 8. Click Browse and locate the firmware file. 9. Click Apply to start the firmware upgrade process. 10.Once the firmware upgrade process has successfully completed, an "Upgrade Success" message will appear to confirm that the upgrade has ended. 11. Unplug the power cord from the back of the router and plug it back in -- this will restart your router using the new firmware.
Posted on Feb 16, 2006
Power light on the router is Blinking very Fast
I have the same problem after doing a firmware update. I did figure out the slow blinking power light means it is in recovery mode and you need to load firmware using the "recovery tool" from Asus' website. I tried loading the newest firmware, the same firmware I had before the problem and the original firmware (all found on Asus' site), but nothing worked.
Did you ever find an answer?
Sep 05, 2013 | ASUS RTAC66U 802.11ac DualBand...
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
Ok so my psp is not turning on the battery is fully charged the green light turns on for acouple of seconds then turns off any tips
Hmmmm... I guess we have a bricked PSP here...
First, I should be right with this - either you tried to install a Custom Firmware (ChickHen) or you were updating and something went wrong.
In order to UNBRICK your PSP, we need to know the following;
1. Your PSP make (Slim or Phat) 2. Your PSP Motherboard (if available)
However, try doing this as this might work if you have a Motherboard that can be recovered from bricking;
1. Press and hold "R" while switching on your PSP. 2. If your PSP boots on into a "Recovery Mode", you're a lucky guy 3. Scroll down to "Run Program at /PSP/GAME/RECOVERY/EBOOT.PBP" and do the rest to recover your PSP's firmware.
Get back if you still have a dead PSP.
Mar 02, 2011 | Sony Video Game Consoles & Games
My psp dosen't have a recovery menu
It DOESNT HAVE A Recovery menu, only Custom Firmware has that.
Sep 06, 2009 | Sony PlayStation Portable (PSP) Console
I cannot connect to the internet but network is working...
did you config the router as an access point?
does the internet work when you by pass the router?
Dec 21, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Philips mp3 player
If you have tried the reset, then it could be one of the following:
1. faulty charger - Need to replace it
2. Faulty/failing battery - Need to replace it
3. Faulty contacts / cable - Need to replace the cable or service the unit for faulty contacts.
If you are able to switch on the unit, try the following:
Please follow the steps below to recover and upgrade your player with the latest firmware:
  1. Make sure that your computer is online and connecting to the Internet.
  2. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC.
  3. Connect your GoGear to the computer while pressing & holding the 070119082257_17362.gif(>||) key until the Firmware Manager recognize the GoGear and a dialogue boxpop up in recover mode.** If you failed going to recovery mode, “pleaseconnect the device in recovery mode” is displayed please repeat step 1to step 3.
  4. Click Start to confirm and start recovering the unit to its factory setting.
    IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
  5. Follow all screen instructions and click Finish at the end to complete the recovery.
  6. The Firmware manager will close automatically once the success message is displayed.
  7. You can now remove your player and start using it again.
You could also try to manually upgrade the firmware and see if that helps...
Oct 12, 2008 | Audio Players & Recorders
Not Loading
i m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
regards..
for any quarry u can mail me at-sigma_shiva1@yahoo.co.in
May 18, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
HOW WILL I RESTORE MY FIRMWARE
If it is a "chi-Pod" or other generic MP3 player, youll have to get on google to see if you can find it, I dont even know if you can get a firmware dump off a friends same model.
Feb 13, 2008 | Televison & Video
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Open Questions:
Linksys (WRT54GC) Router Logo
12,588 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
