Question about Pioneer GM-X324 Car Audio Amplifier
Light flash power
Hello I have a GM-X324. my problem is that I left hook, one months after he stopped walking worse the light flash power any worse over checker but it's correct
Hi. You most probably have a power supply problem. Check capacitors and possible dry joints.
Posted on Sep 08, 2008
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
After 10 seconds running my horizon fitness (quantum ii) , it stop suddently with the E1 code error, what can 1 do to fix-it
The E1 error code is the reed switch signal is not making it to the motor controler. Or that the controler is bad.
Unplug the treadmill and hook it back up, remove the motor hood and check the motor controler for a red light, it should remian lit without flashing, showing the unit has power. When you press the speed buttons, the light should start flashing, then the drive motor should start driving the walk belt. Watch the red light to see if it stops flashing when the belt stops. It should. Does the treadmill read speed and distance before it quits? If so, it most likley is a heavy draw on the drive motor causing too much restistance, which shuts the controler down.
Hope this helps.
Dec 09, 2010 | Horizon Fitness Merit Fitness 725T...
John Deere X324 drains the battery
might have a short in your seloniod switch if you unhook pos from it and there is spark hooking up its probably the short
Sep 08, 2009 | Garden
Anti lock brake lights flashing simultaneously
I would check the brake pads first to see if they are worn badly, spent a lot time once learning that will cause ABS lights to flash!
Grounding the middle pin on the ABS diagnostic plug , turn on the ignition and mash both brakes to see if the bulb checker light goes out! Very important, left out of procedure on IBMWR, if the red bulb checker light doesn't go out you have a blown tail light or stop light bulb and the ABS won't reset!
Or you have a bad bulb checker module underneath the seat. If the red light goes out then the ABS lights should go to flashing then push the ABS reset button and hold for slow count of 10 or so. Release and try it. Hope this helps!
Apr 07, 2009 | 1992 BMW K 75 S
Park lights and dash lights won't stop flashing
There is a small black box under dash by steering column that has a little red button on it. Push that button and it will reset the alarm. Whenever the power is removed from the system it will trigger that alarm and flash your lights. Easy quick fix. Box is about 4" x4" and just to the left of the column. Good luck and have a great day.
Mar 14, 2009 | 1998 Subaru Legacy
No power with amp
make sure the remote wire has juice when the head unit is on then check ground
Nov 25, 2008 | Pioneer GM-7100M Car Audio Amplifier
As i turn volume up amp either cuts off or act wierd
ur pushing to much power throught the amp shutting off the amp and the light might turn yellow on the amp if so then it is that reason
Nov 17, 2008 | Pioneer GM-X324 Car Audio Amplifier
Amplifier won't turn on
You need to confirm that you have voltage on the B+ and ground terminals and have a good ground.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If all of that checks out, the amp probably has an internal fault (blown parts, broken connections...).
Let me know if you have any other questions.
Aug 24, 2008 | Pioneer GM-X324 Car Audio Amplifier
Pioneer GM-X324 Car Audio Amplifier Logo
114 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
