Canon MF 4100 won't print full range of pages (only 1 out of 4). Error red light flashing and message is load correct paper casette :LTR. I have installed it with the correct settings. Casette, paper plan and size a4
  • 2 more comments
  • coolgeek Oct 01, 2008
    I have the same problem. Word documents etc print fine, but many non-microsoft applications do this exact same error with exact same message. I have double checked paper size settings in both Printers setup andin the application itself. All seems OK. Canon offer no help on the topic and blame it on the applications.. ARGH!
  • Anonymous Jan 24, 2009
    I have a similar problem, my Canon MF 4100 prints fine from any program but not from any webpage/from the internet. Any suggestions?
  • Anonymous Jan 27, 2009
  • Anonymous May 06, 2009
    Can not receive incoming faxes, line rings, it makes the transmital sound but then it goes to a busy signal and fax fails
SOURCE: Check Paper size, change paper
Fisr chage your printer settings or preferences to whatever paper you are using in your computer, to A4 or letter or which ever paper you are using, after that you have to erase the jobs on your printer thats why it keeps printing the same document. Here is how you do that.
Step 1 – Remove jobs from the Print Queue
  1. Press the Status Monitor button (button 11)
  2. Press the left or right arrows to select PRINT STATUS
  3. Press OK
  4. Press OK to delete the Print Job
    Note: If there is no job, NO PRINT JOB EXISTS is displayed
  5. Select YES to confirm deleting the job.
After this you chould be clear to print anyother document.
Posted on Jul 25, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
  • 99 Answers
SOURCE: My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Posted on Dec 12, 2009
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
MF 4150 can only print 1 page
Are your print commands ok for printing ALL pages? check
Do you not have the printer manual for troubleshooting?
Jul 14, 2013 | Canon imageCLASS MF4150 All-In-One Laser...
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
Sep 11, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
961 people viewed this question
k24674
jasbo
jasbo
