I have an electrolux EWD1477. In the user manual, it instructs me to clean my filter after every drying load, however it does not describe where the filter is. I have an E20 error, but my pump is clear and my wash cycles are still working fine, so I think this filter may be my problem - but I can't find it!!
  • nadine813 Jan 11, 2009
    Same problem here - no idea where the filter is!
  • 5 Answers
SOURCE: error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
Posted on Jul 18, 2007
SOURCE: E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Posted on Jan 18, 2008
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: E10 & E20 problem
e10 problems refer to water supply..so check the tap is on, the inlet hose is not kinkrd, and the filter in the inlet hose is not blocked.  e20 refers towater drainage,  so check the drain hose isn't kinked and the drain pump isn't clogged
Posted on Aug 19, 2009
Have mislaid the manual for AEG Lavatherm protex plus. Where can I find it online? Can't access the model number as machine set in.
User's Manual - AEG Appliances
www.aeg-appliances.ca/wp.../AEG_LAVATHERM-T65179AV-_manual_070913.pdf
LAVATHERM T65179AV Dryer - ... In the AEG webshop, you'll find everything you need to keep all your AEG appliances ... read this user manual carefully, in-.
AEG - Tumble Dryer user manual, operation instructions
www.usersmanualguide.com/aeg/tumble_dryer 4, Lavatherm 310 A; Instruction Manual - Product Number Code:607625125. 5, Lavatherm 310 w; Instruction Manual - Product Number Code:607625014.
[PDF]LAVATHERM 75280AC EN User manual - User Manuals
www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL...pdf LAVATHERM 75280AC. EN User ... Thank you for choosing this AEG product. We have ..... Dry Plus. Extra Quick. Mixed. 3 kg. To dry cotton and synthetic fabrics,.
[PDF]LAVATHERM 76280AC EN User manual - AEG
www.aeg.co.uk/laundry/laundry/dryers/.../downloadpdf/?...User%20Manual... LAVATHERM 76280AC. EN User .... this user manual carefully, including its ..... Dry Plus . The wool drying cycle of this ma- chine has been approved by The.
AEG LAVATHERM 75470AH USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 75470AH View and Download AEG LAVATHERM 75470AH user manual online. ... filter, er filters DISPLAY Symbol On/Off Dry Plus Reverse Plus Anticrease Buzzer Time ...
AEG LAVATHERM 65270AC USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 65270AC View and Download AEG LAVATHERM 65270AC user manual online. LAVATHERM 65270AC Dryer pdf manual download.
User Manuals ' Service & Support ' AEG
www.aegaustralia.com.au/support/manuals/ Search for user manuals for your AEG products online with our finder tool.
manual for AEG Lavatherm protex plus Google Search
Jun 25, 2017 | AEG Dryers
How to take rear panel off ewd1477 model electrolux
Remove the top panel.
On the upper side, unscrew 4 screws (two left and two right)
on the both sides with the small screwdriver remove the plastic cap and then unscrew one screw on each side (left and right)
Remove the plastic bracket of the water connection by releasing the plastic hook with screwdriver on both sides
Remove a few screws at the rear side.
After that, you should just separate housing halves and got four access almost all components of the washing machine.
Dado
Mar 09, 2017 | Electrolux Washing Machines
Electrolux EWF 1282 start pause button is flashing wont start a load have reset it no error messages came up have also cleaned the drain filter the manual way underneath the machine still nothing any
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 14, 2013 | Electrolux EW1000i Front Load Washer
Electrolux front loader washer ewd1477 flashing start/pause button. interrupted during wash cycle by power outage. start/pause button now flashes and won't start any cycle.
Try to turn circuit breaker off, or unplug unit, for about 5-6 minutes. This is a hard reset and should reset the internal controls to restart the unit properly.
Dec 29, 2012 | Electrolux Washing Machines
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
Same Problem.. not able to find the lint filter on EWD1477
Lou, thanks for your answer, but I think that the original question is to do with the 'mysterious lint trap' that is mentioned in the manual but isnt actually a part of the machine (ie, its a typo / incorrectly edited manual - copied from another model)
The thing we are trying to find is the lint trap for the condenser unit, which is not the same as the drain pump/filter/trap on the bottom right of the unit (or, at least, shouldn't be - if it existed).
I think this model has a specially designed condenser unit that somehow cleans itself from the action of the washing clothes (in your next run), and flushes the lint from any previous drying cycles away with the rinse water during the next wash.
To help keep things clean, you could try to dissolve or at least break up any gunk buildup inside your machine (likely if your not using the 95 degrees C wash temp setting) by using lots of concentrated bleach (at max temp). However, this could damage the machine, but in my experience it is OK. I am not a employee of electrolux nor am I a service person :)
Jun 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
User manual
Hi
Heres the instruction book
http://safemanuals.com/user-guide-instructions-owner-manual/ELECTROLUX/Z77A-_E
Rob
Feb 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
588 people viewed this question
Top Washing Machines Experts
