Question about Haier hwr10xc6 Air Conditioner
E1 problem what is the remote code set on your remote? you can get it by pressing vcr/dvd the hold the set button until it blinks twice enter 990 it will blink 2x then press 1 count the blinks if it diesn't blink number is 0 then go on to 2 and 3 and 4
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
Tip
All For One URC-3220 Code Search
All For One Big Easy Code Search URC-3220
Do you need to search for codes to program your All for One Big Easy URC-3220 Universal Remote Control to control you TV, cable or satellite box, VCR or DVD player?
To program your One For All URC-3220 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
To search for DVD or cable box codes, substitute the DVD or CBL button for the TV button in the steps above.
I hope that helps.
_________________________________
To download One for All Big Easy URC-3220 Users Manual click here.
on Apr 11, 2010 | Televison & Video
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
What sequence do I use to punch in codes 4 a VCR,start to finish?
1. Press the "DVD/VCR" button on the remote.
2. Press and hold the "SET" button on the remote until the red LED blinks twice, then release the button.
3. Enter the 4 digit code for the VCR. (Red LED should blink twice after you enter the code.)
4. Aim the remote at the VCR and press power. The VCR should turn on. If not, try another code until you find the right one.
Oct 07, 2009 | One For All URC-3021 Remote Control
Haier hwr10xc6 Air Conditioner Logo
49 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
