Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Empty wateron DeLonghi Pinguino Pac L 90
How do I drain the water to make the FE stop flashing?
Thanks,
Joe
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
  • 2softball Jul 05, 2011
    THANKS SOOO MUCH,,,HOPING ITS THE DRAIN THAT NEEDS TO BE DRAINED FOR THE AIRCOND TO WORK..THIS WAS A BIG HELP TO GET US TO REALIZE WHATS WRONG...THEY ARE VERY HOT RIGHT NOW AS THEIR BIG HOUSE UNIT WONT BE FIXED FOR THREE DAYS...SHE IS LOOKING TO FIND DRAIN RIGHT NOW,,,KEEP FINGERS CROSSED FOR US THAT THIS IS THE PROBLEM,,,,
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Help please...blinking FE but E does not have top line to the right
Check that the error is not Ft, that means Full Tank.
Drain the internal safety tank through the drain hoses by opening the cover on the rear of the appliance.
there you will find two drain hoses,pull them out, take off the caps, and let all the water flow out.
When finish draining the water place the caps and the hoses back in place.
You also need to clean the filters and let them dry before putting them back in place.
Here is the user manual, see self diagnosis section.
Sep 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
How do i empty the tank
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, fe shows in the display how do you empty the tank.
This is the user manual site.
scroll down to the diagram on page 16 and they describe how to empty the water from the system
http://www.delonghiusa.com/manuals/PACL90.pdf
To empty the tank on the rear of the
appliance.
Pull out the 2 drain hoses, take off the caps
When all the water has been drained, place
the caps back on the hoses and put the
hoses back inside.
Clean the filters and dry thoroughly before
putting them back.
Remember to give me a solved rating before you log off!
Thank You Huuum
Aug 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
It stopped last evening and is flashing what looks like FE
Your water tank is full. Unplug upper and lower hoses, empty into jar and throw away water. RePlug and good to go...
Jul 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
979 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
