Question about Tascam 2488 Portastudio Multitrack Recorder System
DP 02 Info
I purchased a Tascam DP 02 Digital portastudio about 1 week ago. I explained to the guy in the music store that I wished to copy CD music tracks and add a voice over, for use at a community radio station (Intros promos etc) I have read through the Manual thoroughly but can't make much sense of it. Can you recommend any book etc that will give me background on how to use this equipment. I presume that I can use the onboard CD player as the source and then using a microphone add the voice over or is this not possible. Maybe I have to connect an external Cd as an input. I realise this is probably very simple stuff for you but I would greatly appreciate any assistance you can provide.
  • 2 more comments
  • Kaydoo Sep 16, 2008
    Thanks mate for taking the time to assist. I am truly grateful. My entire reason for purchasing the Tascam was to bypass the PC but anyway I understand your fix. Actually I have moved on and connected an external CD player to the Portastudio and can import tracks and assign them to a track in the machine. Walla !! Sadly does not fix. I now have the music on 1 track which is all fine but when I connect a mic ( I am using an ordinary AKG dynamic mic connected thro the 1/4 inch unbalanced mono plug) with the level at the top of the scale you can barely hear the voice over on replay.Even if I just create a new song and only put the voice message on a track it just barely can be heard on replay. I have selected the 1/4" jack to Mic/line as required in the manual but also tried the guitar position with same result. I have tried another dynamic mic, same result. Maybe I have to get an XLR mic and use it. Any further ideas?
    KD
  • Kaydoo Oct 14, 2008
    Thanks Dave
    I managed to get to a guy from Tascam here in Aust. He advised me to connect the Mic up via the XLR inputs because these have pre amps. That did fix the problem. He also advised that it is not possible to use the onboard CD as the source for background music to my voice overs. So it's back to the drawing board in that regard. I've been flatout lately so haven't had the time to fiddle but I do have your previous comments and I will work my way through it in the near future. I must say I thought it would only be a matter of dumping music from a CD to one track then my voice to another track, mixing and mastering and burning it to a CD.The whole idea was to make it simple. Ah well I guess I will learn a lot about the recording process with the Tascam. It's a very clever piece of kit in expert hands but with me a bit like putting a monkey in front of a piano. Thanks for all your help mate. Greatly appreciated
    Ken
  • Anonymous Oct 23, 2008
    I all I boplaught the portastudio DP-02 with the internal Cd burner and have friends help me set it up.
    the one thing I needed to hear what I was playing was a small connector which I just bought and now can hear the demo that it comes with.
    The directions are a little it vague but I went to the music store I bought it from and they showed me tat I needed a YPR-31 SHIELDED cable.
    I paid about 12 dollars for it.
    I used it to connect my amplifier to my guitar and was able to hear myself playing while connected.
    the connector has a 1/4" jack so you can plug your guitar or keyboard to it.
    the other end has two cables that fit into the tascam, they are two plug connectors that fit on the line output where I connected everything.
    I now hear what i play.
    still learning and will post more if I learn more.
    the best start is to read the manual step by step.
    take your time it will work
  • Rosey Rock
    Rosey Rock Aug 11, 2012
    You can hook up a exernal CD player to the line in on the back of the Unit to play music and hook a mic in to B side. Run a guitar cord out of the headphone jack in to a amplifier or PA head. Wouldn't be easier just to have a PA unit and play CD through one of the channels as you spoke through another channel?
    Novelist:
  • 189 Answers
Can't help you with any books for the DP 02, but I can try to assist you in doing what you'd like to do.
The way I would attempt to do this, and there may be other ways but this is really the cleanest in my opinion, (assuming you have access to a computer) is to first rip the CD onto your computer into a series of wav files. Then you'll want to work with one song/CD track at a time. Then you'll need to use a WAV editor (Audacity is a good free one) to convert the wav file from STEREO into MONO wav file. You can then (using the USB import function on the DP-02) import the mono WAV file into the DP-02's fat partition. From there you can load it into the DP-02 by choosing which track to load it into. You'd then be able to play this track while recording your voice overdubs onto another track.
You'd then mix your song and you could burn onto a cd right from the DP-02 (or do as I do and export the mix as two mono wav files back onto your PC and, then convert them back to stereo and when you have all the songs you want for the CD burn a new CD from your PC).
You may have to consult the manual for how to use the USB import/export as well as how to record and mixdown, but I've tried to outline the basic process to do what you want which wouldn't be discussed int he manual.
Hope this helps.
bd
Posted on Sep 15, 2008
  • Dave Hart Sep 16, 2008
    You should be able to use a dynamic mic with a 1/4 jack without any problem. Nothing really to offer except to double check that your input level knob is turned up, that the input your mic is into (A or B) is assigned to a track, and that the track's fader is up and the record button is armed for that track.
    Another thing to look into is whether or not you mic needs phantom power. An unbalanced mic that doesn't need phantom power can be affected by phantom power on its input so if this is the case for your mic you'll want to make sure your phantom power is off.
    If your mic requires it, then perhaps it is off and pressing the phantom power button in to turn it on is all that is required.
    Cheers.
    bd
  • Dave Hart Oct 14, 2008
    Unless there's a problem with your mic it should work the way you're doing it. Are you getting levels registering for the track assigned to record the mic? If so the only other things I can think of off hand is to make sure that your master fader is up when you are listening back as well as the fader on the recorded track and also make sure that the mic/guitar selector switch on the front is set to mic (if you are using the right 1/4" input).
    If you aren't seeing levels you may have a mic that needs more gain than typical which might require a mic preamp (check the rated output for your mic in minivolts.
    I have heard of someone else recently who was experiencing the same problem and using an AKG dynamic mic. I don't know what resolved it in the end, but they had gone through all the stuff I've mentioned here and nothing worked which leads me to thinki that perhaps a different mic is part of the answer. Do you have access to another to test with?
What does it mean meda ERROR 0 TASCAM 01FX HOW TO FIX IT
http://www.fixya.com/support/t2466159-tascam_dp_01fx_cd_media_error_0
Nov 07, 2014 | Tascam Digital Portastudio Dp-01fx/cd
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Overlaying one track onto another
Maybe Tascam can supply information for this.
Jul 07, 2014 | Tascam DP-02 8-track Digital Portastudio...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Tascam DO-02 Master will not light and cannot export tunes to CD for burning. Is there a short cut.?
You might want to post this question in a different section. This is the computer section.
Jun 28, 2012 | Tascam DP-02 8-track Digital Portastudio...
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Peavey PV14 to Tascam DP-02
The usual setup would be to use the main outs to your Tascam as the master faders control the levels there. The control room outs are more geared towards monitoring and are tied to the headphone outs level control.
Apr 20, 2009 | Tascam 2488 Portastudio Multitrack...
I just bought the TASCAM 2488 but find the manual very unclear. Please could you tell me a step by step guide to mastering a song to CD.
There is a DVD vidio manual that I found to help greatly. It is available from most large music stores. Sweetwater.com as example.
Mar 02, 2009 | Tascam 2488 Portastudio Multitrack...
Can't import song from PC to DP-02 Unit and the Manual STINKS!!!!!
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
Sep 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
337 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
