Question about D-Link DSL 500 (DSL-500) Router
Netscaping Can Netscape browsers be used to configure D-Link DSL routers?
    Novelist:
  • 196 Answers
Yes, Netscape 6.2 will work properly with the web page-based interface used in D-Link DSL routers, however, due to problems the browser has loading Java applets and working with Java scripts all of the features may not be visible. Netscape 4.7 does work with the interface, but is extremely slow in loading the various configuration pages. For these reasons, it is recommended to use Microsoft Internet Explorer 5.x or 6.0 to configure D-Link DSL routers. Internet Explorer loads the pages faster and Java applets work properly, as shown below. Note the tree in Fig. 1 (using Internet Explorer), representing the router´s various configuration pages and in Fig. 2, the PPP Connection information. Using Netscape 6.2 as shown in Fig. 3, the configuration tree is missing and in Fig. 4 the PPP Connection Information is not displayed.
Posted on Feb 16, 2006
SOURCE:
I am trying to access the internet wirelessly from a lap top through a D-Link DI-624 I went throught the steps 1. plugged up the router 2. unplugged the DSL box 3. plugged up the ethernet cable to the DSl...
Unplug the power cables from both your DSL modem and D-Link router.
Verify the Ethernet cable is plugged into both your DSL modem and the D-Link router.
Plug the DSL modem power cable back in and wait for the self-test to finish.
Plug the D-Link router power cable back in and wait for the self-test to finish.
Plug your laptop into the D-Link router using an Ethernet cable.
Can you access the D-Link configuration page now?
Check to see if your computer is getting an IP address from the D-Link router.
Here's how to do that, assuming you're using Windows.
Hold down the Windows key on your keyboard then press the letter R.
In the Run dialog box type 'cmd' (without the apostrophes).
Click OK.
In the command prompt window type 'ipconfig /all' (without the apostrophes).
Press Enter.
Look for the line that reads 'Ethernet adapter Local Area Connection'.
Verify that 'Dhcp Enabled' is set to 'Yes".
Mar 14, 2011 | Computers & Internet
Access into setup
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 28, 2011 | D-Link DSL 500 (DSL-500) Router
Every time I try to access my DI 514 screen i get my internet provider DSL configuation screen
I presume you are attempting to access your router by typing the numeric address (e.g., 192.168.1.1) into your browser.
The address you are typing into your browser is apparently the address of your DSL modem, not your wireless router. This address may be subtly different, e.g., 192.168.0.1.
I suggest you pull up the window that shows your computer's network address, its netmask, and its server address. The server address is the one you need to type into your browser.
If this still gets you your DSL modem, it could be that you have configured your router to provide the same range of addresses on its LAN side as your DSL modem provides on your router's WAN side. This is an unworkable configuration. You will need to disconnect the DSL modem from the router so that you talk ONLY to the router, and change its configuration to use a different address range.
It's hard to get more specific without knowing what addresses you are using or how your network is set up. The above is a general overview of what you need to do to solve this problem.
Feb 16, 2010 | D-Link DI 514 Wireless Router (DI-514)
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys Wireless-G (WRT54GS (EU/LA/UK))
I have had that issue quite often and found that when you are using a router with DSL, the DSL modem and Router IP has a conflict because they are the same number. I suggest looking into a D-Link wireless router for use with DSL.
Mar 17, 2008 | Linksys Wireless-G WRT54GS Router...
AOL DSL Plus
AOL DSL+ now uses PPPoE for authentication bypassing the client software. To set up your router: Step 1 Log into the web-based configuration of your router by opening a web browser such as Internet Explorer or Netscape and enter the IP address of the router (192.168.0.1). Enter admin for username and then your password (blank by default). Configure the WAN side to use PPPoE. Please consult your manual for login instructions since all routers are not the same. Step 2 Enter your screen name followed by @aol.com for the user name. Enter your AOL password in the password box. Step 3 You will have to set the MTU to 1400. AOL DSL does not allow for anything higher than 1400. Step 4 Apply settings. Step 5 Unplug (turn off) the power to the modem and router. Wait 1 minute and then power on only the modem. Wait about 1 minute and then power on the router. NOTE: If you connect to the Internet with a different Internet service provider and want to use the AOL software, you can do that without configuring the router?s firewall settings. You need to configure the AOL software to connect using TCP/IP (LAN). Contact AOL for more specific configuration information of their software.
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
AOL DSL Plus
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Internet connection provided by AOL DSL Plus
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link DSL 500 (DSL-500) Router Logo
128 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
