Question about Panasonic Lumix DMC-TZ3 Digital Camera
Change the ISO
How can i change the iso to 1600?
  • monday481 Sep 08, 2008
    cant find it in the manu
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Lumix DMC-TZ3
See page 51:
The max ISO for this camera is 1250.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 08, 2008
When shooting in daylight, view screen normal, resulting photo is "whited out", ok inside house in house lighting. Just started.
Look in settings for the ISO value. This is the speed of the 'film' and how it reacts to light. The higher the ISO, the better it can deal with low light conditions. A standard ISO for normal daylight would be ISO 200. Your is set to something like ISO 800 - 1600.
Jan 13, 2016 | Sanyo Xacti VPC-S770 Digital Camera
Kodak Z712 ISO
go to manual mode to change it sir.
Jun 15, 2008 | Kodak EasyShare Z712 Digital Camera
How do i change my iso setting
Your camera is capable of ISO adjustments from 100 to 1600. Photos taken at ISO 100 require the longest exposures and will have the best quality color and least amount of graininess. This setting should be used as often as possible and is ideal for well lit subjects. Conversely, ISO 1600 is for low light situations. Photos taken with the camera set to this value will have muddied colors and much more graininess in them. This is often preferred to having no photo at all.
The down side to this camera - like most point & shoot ("P&S") types, is the fact the the light sensor that actually captures the image from the lens, is quite small. Small sensors have difficulty rendering acceptable photos when taken at high ISO settings. It is not unusual for P&S cameras to perform unacceptably at ISO 400 and up. Reviews I have seen on your camera back this up. Basically, ISO 100 and 200 are the only values that provide acceptable photos. You should experiment with the entire range of ISO under different lighting conditions to see which situations and ISOs are acceptable to you.
Your camera makes use of icons to access menus and they do not show up well on FixYa, so I will need direct you to an online manual that you can view or download. It can be found here.
Chapter 3 (begins on Page 16) talks about camera menu settings. Your should review this chapter, and pay particular attention to "ISO" on page 20. You will learn how to select ISO 100, 200, 400, 800 & 1600 on the camera.
I hope this helps & good luck!
Sep 27, 2012 | HP Photosmart R937 Digital Camera
Nikon ISO D100
Sounds like you are set in ISO AUTO. This will change your ISO when you are in light that is low enough to give underexposure. In most of the shooting modes, the D100 will change shutter and/or aperature to prevent underexposure, but if it can't avoid the underexposure, it will change the ISO to correct the underexposure.
It also sounds like you have a low light shooting situation. The blur you see is likely from the long exposure, which is pretty hard to hand hold. Noise in the picture would be from the high ISO, but if it's a noise problem you probably don't have blur.
Avoiding the blur is best done with a tripod or a shutter speed of at most 1/60. If you can't get a good exposure at 1/60 or faster, then try the tripod. If you can't use a tripod, then let the ISO (in auto) go up to 1600 and then remove the noise with photoshop or another photo editor. You'll have to play around with the noise reduction settings to get one that works for you.
The key to low light photos is to make sure you get an exposure that isn't blurred, even if you have to use a high ISO. It's easy to remove the noise in software, but blurry photos can't be fixed.
Oct 11, 2009 | Cameras
Kodak C643 dark pictures
Change to a higher ISO sensitivity setting. It is probably on 80. Change to the highest setting which is probably 400. If you can get much higher, like 1600, then try that.
If you use the flash, it may be better to not use it... try a few pix with & without the flash (after you set the ISO to the highest setting).
Next camera, get one that will go to 1600 or 3200 ISO.
Hope this helps!
Sep 08, 2009 | Kodak EasyShare C643 Digital Camera
ISO AUTO ERROR
Need more information regarding your question.
If your error is about your images being brighter/darker whenever you shoot at different locations, then this is a normal feature when using Auto setting for your ISO. The exposure will always slightly change whenever the ISO changes.
If your problem is about too much noise, then this is a normal problem when you use very high ISO on the D80. You can remedy this by setting the max ISO to 400 but you will not be able to take non-flash pics in darker environments.
If your problem is the ISO levels do not go up a certain setting, change your MAX ISO setting to a higher number like 1600. At this setting, the pictures will be grainy and have a lot of noise so I recommend you convert the output to black and white.
NOTE: Please rate our help to keep this free service online
Jul 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Tips for Canon A560
You can select the shutter speed in the following range
Shutter speed 15-1/2000 sec
ISO sensitivity • Auto
• ISO 80
• ISO 100
• ISO 200
• ISO 400
• ISO 800
• ISO 1600
Thanks
proton
Oct 11, 2008 | Canon PowerShot A560 Digital Camera
Adjusting light??
Did you check your settings? You may be outside of the range (red figures for speed and or f stop) in your selected mode, for example if you selected 1600 ISO for indoor shots and forgot to set it back to a lower ISO value.
Alternatively you can use AUTO mode, it's the most foolproof.
If you selected 1600 ISO don't forget, when you change the ISO to a lowe value, also put the camera back in high resolution, it stays in 1MP mode by default.
HTH...
Jul 07, 2008 | Fuji FinePix S602 Zoom Digital Camera
Trying to take pictures in low light conditions inside a theater.
when you use high ISO like 800-1600 it will create big novice on image, and when you using law ISO it will be dark for sure.
so the solution is switch cam to TV mode and put into very law shutter speed and use ISO 200-400,make sure you are connected to tripod or else you will not get fine results with law shutter speed. point is when you use law shutter speed camera will take more light to censor even with law ISO your images will be perfect.
Dec 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
59 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
