Question about Tascam 2488 Portastudio Multitrack Recorder System
TASCAM 788 Porta-Studio......the faders do not have an effect in the monitor headphones.....they are working internally, I think, as I can see the little icon moving.....the faders work when setting record levels......however, during playback they do not respond.....what's the deal? I don't know if something has failed, or I do not have something switched correctly.
4 Suggested Answers
SOURCE:
  • 189 Answers
SOURCE: vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Posted on Sep 15, 2008
  • 189 Answers
SOURCE: tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Posted on Oct 23, 2008
dunnbiker
  • 8546 Answers
SOURCE: How to download from the Tascam 788 to the CD
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 8
Posted on Feb 20, 2011
Were can i get my tascam porta 4 track fixed in herefordshire
These unit are long past their life expectancy and I do work on them and get them going but I am located near Chicago, IL USA.
Generally they need cleaning, lubrication and some new belts.
Jan 25, 2013 | Tascam Porta 05, Porta One & Two Belt Kit,...
How do you eject a tape from a Tascam Porta Two ministudio? It's a quite dated model, yet there is no eject button.
This type of model does not have an eject button as the deck is designed so that when the head is retracted as in stop mode you simply pick up the door and pick the tape out of the well. This is pretty much the same in all the lower end Porta Studio models.
Jul 01, 2011 | Tascam Audio Players & Recorders
Need tascam porta 07 manual
Havent find the porta 07, most simmilar I think is porta02. I suggest to go to the http://www.tascam.com and and look in right corner in same line with the menu (under- legacy products). When you choose the product an image will came. Go to the RESOURCES tab to get the manual.
This site has a service manual for 17$:
http://www.bonanzle.com/items/search?item_search_page[only_title]=0&item_search_page[search_term]=SERVICE+MANUAL+TASCAM
Aug 06, 2010 | Audio Players & Recorders
Peavey PV14 to Tascam DP-02
The usual setup would be to use the main outs to your Tascam as the master faders control the levels there. The control room outs are more geared towards monitoring and are tied to the headphone outs level control.
Apr 20, 2009 | Tascam 2488 Portastudio Multitrack...
Cant restore levels
Sounds like you might have 'Fader Matching' set to something other than 'Real' mode which can cause the physical fader positions to be mismatched with the internal fader settings (useful for saving scenes, and used on the 2488 because there are no motorized faders). You can go into the 'Mixer Preferences' Menu (under the 'Preferences Menu') and check the what is set for fader matching. If it is set to 'jump' or 'catch' you should change this to 'real'.
You also might have a particular 'scene' being recalled which has a lot of saved settings that are affecting the levels.
You can refer to pages 39 and 92 (in the MkII manual) for references on scene memories and fader matching.
Hope this helps.
bd.
Feb 03, 2009 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Sound
No sound during recording ? No sound during playback ? Both ?
Do you have signal levels on the meters at stereo/ main out ? If yes then make sure master fader is at adequate level then check to see if there's a headhone on/ off switch or a headhone volume level  knob, if so then adjust ( be careful not to have the master fader at a high level when you turn on the headphones, it hurts )  If you don't have signal on the stereo/ main out meters or you do and the above steps didn't work then we'll take it from there.
Jun 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tech support
http://www.tascam.com/i-874-232-128-0-540B4588.pdf
Mar 04, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Tascam 2488
In the monitor section on the 2488 console (upper right) make sure your monitoring source is set to 'stereo'. Then make sure your 'monitor level' control is turned up. The 'stereo' fader (sub mix fader on the MKI, stereo fader on the MKII).
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
44 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
