Question about D-Link DI 804V (DI-804V) Router
Resetting the router
How do I reset the DI-804V?
    Novelist:
  • 196 Answers
There are two ways to reset the unit back to the factory default settings. Through the web-based interface: Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the System Tools tab and go to the Load Default Settings tab on the left. Step 3: Click on the Start button to proceed. This will now load the unit back to factory settings. Note: The Device IP Address will be reset to 192.168.0.1 after loading the default settings. Perform a hard reset: Step 1: Power the unit off by unplugging its power adapter (from the unit, not the wall). Step 2: Insert a paper clip into the reset pinhole. Press and hold the reset button with light pressure. Step 3: Power the device back on by plugging it in. Continue to hold the reset button. Step 4: Watch the lights on the front of the gateway. The status light and wireless light will power off. Once both lights are powered off release the reset button. Step 5: The unit will reboot and now will be reset to default settings.
Posted on Feb 16, 2006
2 Suggested Answers
  • 196 Answers
SOURCE: VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I need help resetting a password. I can't send or
  • it jas to reset and reconfigure the router. call dlink support
Aug 08, 2009 | D-Link DI 514 Wireless Router (DI-514)
Hi. i cant connecct my VPn
- Make sure you have an updated firmware on your router and after wards kindly visit this site for further instructions:
http://support.dlink.com/faq/view.asp?prod_id=1384&question=DI-804HV%20/%20DI-804V%20/%20DI-808HV
Mar 15, 2009 | D-Link DI-808HV Router (280006OB)
Can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
VPN
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
How do I upgrade the firmware on my DI-804V?
To upgrade the firmware on a DI-804V follow the steps below: Step 1: Download firmware from our support site. Save and unzip it to your desktop. Download Firmware here. Step 2: Access the configuration page by entering 192.168.0.1 in your web browser. Step 3: Click on the System Tools tab and then click Upgrade Firmware on the left side. Step 4: Click the Browse button and locate the firmware file that you have downloaded and unzipped. Highlight this file, click Open, and then click Start. Note: When upgrading the firmware, do not try to access the Internet and do not turn the power off. Doing so may cause the firmware upgrade process to abort, which will damage router.
Opening ports
To forward a specific application port please follow the steps below: Step 1: Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Step 2: Click on the Advanced Settings tab and then select Virtual Server from the left side. Step 3: Enter the last three digits of your IP address on the field provided and then enter the range of ports that would like to allow in. If you would only like one port to be opened, then enter the same number in each box. Step 4: Click Submit and then Save and Restart when prompted.
Configuring the DI-804HV/DI-808HV
Step 1: Log into the web based configuration of the router by typing in the IP address of the router (default: 192.168.0.1) in your web browser. By default the username is admin and there is no password. Step 2: Click the VPN button on the left column, select the checkbox to Enable the VPN, and then in the box next to Max. number of tunnels, enter the maximum numbers of VPN tunnels that you would like to have connected. Step 3: In the space provided, enter the Tunnel Name for ID number 1, select IKE, and then click More. Step 4: In the Local Subnet and Local Netmask fields enter the network identifier for DI-804HV´s LAN and the corresponding subnet mask. Step 5: In the Remote Subnet and Remote Netmask fields enter the network identifier for the DI-804V´s LAN and the corresponding subnet mask. Step 6: In the Remote Gateway field enter the WAN IP address of the remote DI-804V and in the Preshared Key field, enter a key which must be exactly the same as the Preshared Key that is configured on the DI-804V. Step 7: Click Apply and then click on Select IKE Proposal... Step 8: Enter a name for proposal ID number 1 and select Group 2 from the DH Group drop-down menu. Step 9: Select 3DES as the Encryption Algorithm and SHA-1 as the Authentication Algorithm. Step 10: Enter a Lifetime value of 28800 and then select Sec. as the unit for the lifetime value. Step 11: Select 1 out of the Proposal ID drop-down menu and click Add To, which will add the proposal that was just configured to the IKE Proposal Index. Click Apply and then click Back. Step 12: Click on Select IPSec Proposal... Step 13: Enter a name for proposal ID number 1 and select None from the DH Group drop-down menu. Step 14: Select ESP as the Encapsulation Protocol. Step 15: Select 3DES as the Encryption Algorithm and MD5 as the Authentication Algorithm. Step 16: Enter a Lifetime value of 3600 and then select Sec. as the unit for the lifetime value. Step 17: Select 1 out of the Proposal ID dropdown menu and click Add To, which will add the proposal that was just configured to the IPSec Proposal Index. Click Apply and then click Restart. Configuring the DI-804V: Step 1: Access the router?s web configuration by entering the router?s IP address in your web browser. The default IP address is 192.168.0.1. Login using your password. The default username is admin and the password is blank. Help Accessing Web Management Step 2: Click on Basic Setup and then select Device IP Settings on the left. Step 3: Change the LAN IP address so that it is on a different subnet than the LAN of the DI-804HV (ie 192.168.1.1). Step 4: Click Next until you reach the Save & Restart screen. Click Save & Restart and then click Basic Setup once the unit has rebooted. Step 3: Click on VPN Settings. Step 4: Name your VPN connection and click ADD. Step 5: In Remote IP Network and Remote IP Netmask fields enter the network identifier and corresponding subnet mask of the DI-804HV´s LAN. Step 6: In the Remote Gateway IP field enter the WAN IP address of the DI-804HV and make sure that the Network Interface is set to WAN Ethernet. Step 7: Verify that Secure Association is set to IKE and that Perfect Forward Secure is Disabled. Step 8: Verify the Encryption Protocol is set to 3DES and enter in your Preshared Key. The Preshared Key needs to be identical to the one configured on the DI-804HV Step 9: Leave the Key Life and IKE Life Time values at their default levels and click SAVE. Step 10: Click Next and then click on Save & Restart Establishing a connection: Step 1: Open a command prompt (Start > Run and type CMD) and from a computer on the internal LAN of the DI-804HV, ping the IP address of a computer that is on the internal LAN of the DI-804V, or vice versa. Step 2: Once you begin to receive replies, the VPN connection has been established. Step 3: To view the Status of the VPN on the DI-804V, click on Device Status. Step 4: From the Device Status screen click on VPN Status. Step 5: When the VPN has been established, the Status will be Active.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Open Questions:
See all D-Link DI 804V (DI-804V) Router Questions
D-Link DI 804V (DI-804V) Router Logo
102 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
