Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
Philips 60PP9363H Blue shadow and Sensors not verified
The TV is a Philips 60PP9363H. The first problem is the convergence on the blue is off in the upper right hand corner and lower center of the screen causing blue shadows in those areas of the picture. My second problem is when I ran a sensor test I got an error massage reading "Sensors not verified at locations: 1234"
  • 1 more comment
  • pit_deamon Sep 08, 2008
    I'd like to fix the problem myself if possible. I am well versed and practiced in using a multi meter. I have done some electronic repair and I'm a capable solderer.
    Where is this part located in the tv set? Does anyone have a schematic?
    The answers were very helpful I thank everyone who offered their input.
I have a yellow and blue shodow in the right and left corners of the tv
Posted on Jan 14, 2009
    Brigadier General:
  • 5,158 Answers
What is the chassis number for that tv ?
Robert
i'm trying to find the service manual
Posted on Sep 08, 2008
  • Roberta Smith
    Roberta Smith Sep 08, 2008
    never mind i see you have a solution
    Robert
    Genius:
  • 2,035 Answers
First you need to try this :You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. and you still have same problem then I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new SKT IC"S. heres the link.
http://servicemanuals.vstore.ca/
Good luck....
    Master:
  • 638 Answers
The convergence problem is due to the stk ic which needs to be replaced to solve the problem.
thanks.
  • 4,472 Answers
Are you trying to repair this yourself or have it repaired? It is a convergence problem. Please don't reject my help until I have all the information needed. You can always accept and rate a solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 08, 2008
    Ok but by continuing to look for another experts help you discourage the people who already have tried to help you that is why I told you not to reject my help til I had more information. I can still help you if you decide to reconsider the rating. I would recommend purchasing the service manual and going from there.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 08, 2008
    https://www.manualsparadise.com/ShowProd...
    schematics and/or service manual can be purchased from that link.
    Thanks,
    Lee
    Genius:
  • 1,847 Answers
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Check the blue horizontal convergence amp on the convergence panel.
Whether or not this is an in house solution, is up to your experience in electronic repair and specifically TVs.
Good luck
  • Legin Varghese
    Legin Varghese Sep 08, 2008
    Convergence problems are generally simple repairs, presuming you know
    how to solder and have a bit of brains about you. Eventually every
    projection set will have this problem - STKs are usually at fault
    (STK392-010/020/040, STK392-110/120/150/180, etc) and are easily
    aquired and replaced. Sometimes a fusible resistor is taken out in
    power supply circuit, sometimes a resistor will burn. Generally easy
    fix. Repalce STK and any fusible/blown resistor - you will need a
    multimeter, decent soldering equipment (NOT a 40watt iron or gun from
    Radio Shack, unless you're brave) and the replacement parts. But as
    everyone says - servicing TVs can be hazardous. Call a servicer if
    you're concerned, but in-shop repair should cost less than $250 - it
    would never exceed that at our location.
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Philips 60PP9363H/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Blue shadow
If the blue shadow is convergence you should have an option for convergence adjustment via the remote control to converge the blue onto the green. If it doesnt move then its probaly a IC problem. What make and model set do you have?
Jan 02, 2008 | Televison & Video
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
