Cars & Trucks Logo
Anonymous Posted on Aug 22, 2011
Reset change oil light on 2004 bruick revendevo
Randy Ohler
Level 3:
  • Buick Master 14,585 Answers
  • Posted on Aug 22, 2011
Randy Ohler
Buick Master
Level 3:
Answers
14585
Questions
8
Helped
3946214
Points
39683
Most vehicles is to turn the ignition on, press the gas pedal three ties with in five seconds slowly. The light will either go out or start to flash. when its done flashing it will reset.
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
0
Helped
23003
Points
251
Hi there
to reset this turn your ignition on without starting and press accelarator all the way down three time within five seconds the oil light will flash twice and you will have reset it have a wonderful day and thank you
  • Anonymous Aug 22, 2011
    You people& fast & good Thanks
  • Anonymous Aug 02, 2012
    Can you reset a pass key as easily?
tip
Reset oil change light on 2004 Oldsmobile Alero or Bravada w/o (DIC) Driver...
I see alot of people cant figure out how to reset there oil change light on a 2004 Oldsmobile Alero/ Bravade w/o (DIC) driver information center. To do this follow the steps below.
Turn the ignition to ON, with the engine off. Fully depress and release the accelerator pedal slowly three times within five seconds. The reset is complete when you hear the chimes and the “CHANGE OIL” light goes out. If the light stays on and no chime is heard, you will need to repeat the reset procedure. Turn the key to OFF. If the “CHANGE ENGINE OIL” message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure.
and its as easy as that and now you can change your oil on your own and not need a dealership to reset it for you.
2answers
2answers
How do i reset my manint req's light after an oil change on a 2003 Honda pilot
Reset oil service light Honda Pilot. From years: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012.
How do you reset oil service light Honda Pilot. From years: 2003, 2004, 2005.
  1. Turn off the engine. Press and hold the SELECT/RESET button in the instrument panel and turn the ignition switch to run (one position before starting).
  2. Hold the button for at least 10 seconds, until the indicator resets.
  3. Turn the ignition off and then start the engine to verify the indicator has been reset.
How to reset oil service light Honda Pilot. From years: 2006, 2007, 2008, 2009, 2010, 2011, 2012.
Resetting the Engine Oil Life Display if maintenance service is done by someone other than your dealer, reset the maintenance minder as
follows:
  1. Turn the ignition switch to the ON (II) position.
  2. Press the select/reset knob repeatedly until the engine oil life is displayed.
  3. Press the select/reset knob for about 10 seconds. The engine oil life and the maintenance item code(s) will blink.
  4. Press the select/reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to 100.
All information is taken from the Honda Pilot owners manual.
4helpful
2answers
How to clear the change oil message in the information center on a 2004 Tahoe
GM OIL LIFE SYSTEM - RESETTING
Reset the oil life monitor when the oil has been changed, use the following procedure.
1. Turn the ignition key to the RUN position.
2. Fully push and release the accelerator pedal 3 times within 5 seconds.
3. If the Change Oil Soon light flashes, the system is resetting.
4. Start the vehicle.
5. The oil life will change to 100%.
6. If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
9helpful
Reset oil light in 2004 alero
Oil lights can not be reset,but the oil change light can,,Turn the key to on,and push the accelerator 3 times slow ,with in 5 seconds,this will turn the oil change light off.If this was helpful,please rate thank you.
1helpful
Reset change oil light on 2004 Grand Am
turn key to on position (do not start). wait for change oil light to illuminate. fully depress the gas pedal to the floor 3 times in less then 5 seconds. wait another ten seconds, then start the car. the light should be out. good luck!
5helpful
2answers
2004 Nissan Murano How do you clear maintenance light after oil change?
press maintanence button until you see engine oil, then hold trip/reset button... :)
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
