Question about Dell OptiPlex GX260 PC Desktop
CHKDSK when I boot or reboot a 5 stage CHKDSK program comes up that runs for 45-50 mins. how can I change this to avoid the wait
    President:
  • 2,961 Answers
You must have had a system crash, windows automatically checks for bad sectors and corrupted files the next time you boot up.
Allow it to run because it will repair any bad sectors, after that it will not run again on start up.
Posted on Sep 08, 2008
Delated 5 threats laptop turned off cannot get it to reboot
I presume you ran a program that deleted the threats for you. If so, don't use that program again because it sounds like it doesn't do its' job properly.
If you pc doesn't boot now, the best thing to do is either:
use your installation disc to repair windows using chkdsk in the recovery console
OR
download hirens boot disc, put it on a cd, boot into mini windows and run chkdsk on your hard drive from there.
If you don't know how to do this then please contact your local friendly pc repair man to do it for you.
Jun 04, 2013 | Computers & Internet
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
Tip
How to check the PC system for errors, repair the damages or check disk.
1.) Go to 'Start'
2.) Press run and type CMD
(You will see a box eg: C:WINDOWSsystem32CMD.exe )
3.) Type CHKDSK , press enter
*CHKDSK is verifying files (stage 1 of 3) You have to wait for a few seconds/minutes.
Then you will get a message 'run chkdsk with /F (fix) option to correct these'.
4.) Type CHKDSK /F . press enter
( *Remember there is a space between Chkdsk and F: chkdsk<space>/F )
Again, you will get a message 'chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
5.) Type Y
You will get a message ' This volume will be checked the next time the system restarts.
6.) Now, exit the box and restart your computer.
It will the check the disk. You will see this on your screen as you restart 'A disk check has been scheduled. Windows will now check the disk (stage 1-5)'
*Note: It will take some time to check your system disk. You need to perform 'check disk' regularly so that you can speed up your PC performance and to repair damages in your system.
* You can try it on any kind of Windows PC.
on Jan 25, 2010 | Computers & Internet
How do fix a crashed laptop that keep on restarting
If you dont have windows CD or DVD press F8 after rebooting(to start Safe Mode)
Choose Safe Mode
Uninstall any programs that you install lately that may cause that problem
Then restart your computer
If you have Windows CD or DVD
1.Boot From CD (you have to change boot options accesing BIOS: F1,F2, F10 or delete Key )
2.Choose R to run Windows Recovery Console
3.type 1
4. Enter your admin password
5.Type : CHKDSK -R
6. Let it run
7. Done
Nov 18, 2010 | Computers & Internet
I have a NEC powermate computer, to remove a possible virus, I disabled system restore, rebooted into safe mode, and tried to install symantec in safe mode (I failed to install), Then I rebooted the...
Win XP is obsolete. Whatever happens it will go through the BIOS stage, if not the hdd may be corrupted. Boot into safe mode and run CHKDSK/f. That may cure your problem otherwise reinstall XP from your CD.
Aug 24, 2017 | NEC PowerMate ML4 PC Desktop
My computer is running slow it takes 10 mins to load up from start
things to try ,
1 depending if you have windows vista or xp or 7
if vista start, all programs, accessories, Command and prompt, Right Click it then run as administrator.
if xp just click it,
then Type chkdsk /f
this is a command to scan the computer for errors and fix them. reboot the computer and wait for it to do the scan this should make it a bit faster , try defragment , delete your browser history and cookies, disk cleanup on accecoties,system tools
Feb 17, 2010 | Computers & Internet
I have samsung x10 laptop unable to boot
if you have the install disks for windows you can try to run a "chkdsk" with the cd. Put the cd in the computer, reboot the computer (please make sure you have the cd as the first option in the boot session), then type r (for repair) and then type chkdsk and press return, and let the program check for corruption on the HD, after the program has run then take the cd out and reboot the computer.
Hope that helps
IF NOT then try to return here
Have a nice day
Please rate my answer
Nov 25, 2009 | Computers & Internet
HP dv9700 was working fine. Re booted after it froze and now it's super slow. 20 min for password screen to come up. HELP!!
If it is extremely slow, then what has happened it alot of windows has corrupted. If you have your recovery disc, the simplest method is to stick in the first disc and reboot to it.
Fix the boot sector with it.
Aug 09, 2009 | HP Pavilion dv9700t Notebook PC
PC does not boots / does not start
Since your system reboots even if you stay in the Bios setup the problem with your system might be because of heating up of the proceesor, which might be caused if the fan CPU fan is rotating slowly or is not rotating at all. If the fan is rotating slowly change the cpu fan and try to reinstall XP
Jun 29, 2009 | Computers & Internet
PC does not boots
Change the SMPS, preferably with 450 & above wattage. Also you must be using an UPS(uninterrupted power supply or battery back-up so there are no chances of voltage fluctuation. At the time of changing the SMPS also remove the RAM and clean the contact points with a piece of normal white paper..............sodeep
Jun 28, 2009 | Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
