Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Date time problam
When i re boot my computer my compuer date allways change
    President:
  • 2,961 Answers
Your cmos battery on the motherboard (CR2302) needs replacing, it looks like a large flat watch battery, just flick it out replace with a new one, reset the time and date and it will be ok after that
Posted on Sep 08, 2008
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
How to Clear Your Computers CMOS to Reset BIOS Settings
Oct 06, 2016 | Computers & Internet
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
Bad back-up battery
If the computer cannot keep the Date and Time after you set it and when you boot up next time the Date and Time has changes or not set then the BIOS battery is flat and needs to be replaced.
When you remove the case the BIOS battery most likely will be a coin size 3volt lithium battery, type CR2032.
After replacing the BIOS battery, boot up the computer and go into the BIOS setting and set the Date & Time etc.
Jun 13, 2012 | Compaq Presario S4000NX (DF213AR) PC...
Date problem
When the Date and time error message comes up during booting up the computer, it means the BIOS requires configuration.
If this occurs every time you boot up your computer after changing the Date and Time then, this is caused by a flat BIOS battery.
The BIOS battery is ususlly a 20mm dia. 3 volt lithium battery type CR2030
Replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Computers & Internet
Please run setup invalid configuration information
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong.
If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery.
If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Dell INSPIRON 6000 CENTRINO...
We are making a sports highlight video. The video came off a Sony Handycam. We viewed the tape using the handycam to reference sports plays to edit using the time/date data in the lower left of the...
I use this information in photography, its caled EXIF Data, and basicaly is the internal information stamp in the pic (date, camera type, focus used, expsure range, etc, etc).
EXIF data on each movie clip recorded is stored in the accompanying .THM file which is a small JPEG thumbnail file of the first frame of the movie.
Force open the *.thm file with photoshop (or simply make a backup copy and change the extension to *.jpg) and read the EXIF via Ctrl+Alt+Shift+I.
I know that the video files also keep this information and could be vewer and modificated; try to check this software and apply it: topshareware.com/sony-camera-exif/downloads
Additional details could find in this site: www.exif.org
Just one last personal recommendation: ALLWAYS, ALLWAYS keep some backup copy about your files.
Good luck.
Apr 27, 2011 | Sony Handycam DCR-TRV140 Digital Camcorder
Use abit nf-m2s mobo...boot till bios okay..but after boot screen of windows...it turn off unexpectedly..help
first of all remove cd-rom from ur computer and see , if it is solved then ur smps is not taking load , and then too u have same problame then replace the smps. this will definitely solve ur problame.
Feb 28, 2011 | Computers & Internet
BSOD when turning compuer on c0000021a
You need winxp bootable disk for format or repair your winxp.
Then boot your computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then set first boot device in bot option as your cd or dvd rom.Then save settings .
Then put your disk in rom then it boot with it.
Aug 01, 2009 | IBM ThinkPad R51 Notebook
My computer won't start up right
press F1, when it boots you are going to have to go down to the date and time, and click on it then you will need to put in the correct day date and time. If pressing f2 it will take you into the bios, and you can set it from there prior to booting, unless you know what you are doing, stay away from the bios, it can really screw up your computer. Good luck and Peace,Gym
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Emachines T1840, Computer will not get past start screen
I had the same problem, what i did is unplug it, wait for like 10 min, then plug in the wire and start it. It worked. Try it.
Sep 18, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
