Question about Microsoft Windows XP Professional
Restart My computer can not enter into windows coz it will restart after booting. Is this a software issue or hardware?
  • nph33 Sep 09, 2008
    One of my computers is stuck in a loop. I believe it occured because I stopped in the middle of a Windows update. I've tried cold boots. I've tried reinstall with the XP pro CD and get a 'Do you want to boot from CD but it gives me same startup then stalls and returns me to the improper shut down window. I'm considering putting a new hard drive in and installing XP then connect the old drive as an external drive and see if I can recover the data.
    Guru:
  • 1,049 Answers
I would bet even money that it is your software, not your hardware. But rebooting does NOT always fix this. Because this often happens when the OS can not initialize a core device like your system board, video, etc. For example, take a Windows OS loaded on an Intel PC and move it to a PC using an AMD processor, "Yeah, good luck!". Similarly, drive failures can also cause a perpetual reboot, I had it happen when a Windows 2000 computer crashed during a defrag of the system drive. In these cases I have always had to either restore the system partition, restore the registry (hard in Win2K), or reload Windows completely. Even trying "fixmbr" or "fixboot" in the recovery console didn't help.
If this is the case for you and your not doing NT backups on this machine, I recommend doing an NT backup of a similar machine and restore the system state from the recovery console.
Posted on Sep 12, 2008
    President:
  • 2,961 Answers
It is stuck in a loop, when it is rebooting turn it off at the power button on your pc.
Turn it back on, then it should say windows shutdown unexpectidely and then prompt you to start windows as normal, highlight it and press enter.
Posted on Sep 08, 2008
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
Windows failed coz of critical system driver is missing or corrupt.. volsnap.sys status 0xc0000098
That can be frustrating :( hope my solution below helps..
based on the current situation, I suggest trying the following steps: restart the computer and keep pressing F8; Use Last Known Good Configuration.
If the issue still occurs after that, I suggest testing if we can boot from a Windows disk. If so, please install Windows on another partition and access your important data. After backing up those data, you can use Windows disk to format the drive and reinstall Windows.
However, if we cannot boot from a Windows disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
May 26, 2011 | Computers & Internet
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
My computer msi brand is automatically restarting and some problem are appear but i cant read becouse it is continusly restarting...i rem the time when im not in my mood and keep badtrip to my computer so...
You have two options to remedy the problem. You really need to access the computer in Safe Mode and view the System Logs to determine the offending piece of hardware or software or virus. But your real question is how to stop the reboot. Use the F8 Key during boot. Right after you turn the computer on, start hitting the F8 Key. The Windows Boot MEnu will appear. at this point you can do one of two things to try to fix the problem. You can enter the computer in Safe Mode which load Windows with only the minimal necessary hardware and software drivers.If you want to see the error message, choose option 8 which tells the computer not to automatically restart after an error. This will enable you to determine the error message on the screen and prevent the system from just going through an endless loop of starting, erroring-out and restarting..
F8 (during boot) Holding F8 when booting displays the Windows Boot Menu
SHIFT (during boot) Holding SHIFT down when booting forces Windows into Safe Mode
Let me know if I can be of any other assistance to you
May 15, 2011 | Microsoft Windows 7 Professional for PC
When the computer boots, the loading Progress Bar of Windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black.
Welcome to FixYa
Dear user
This might be Hardware or Software Issue.If you have installed any New Hardware of Software Simply Remove it .And Try to Boot.In case of Software,Try to boot in SAFE-MODE by pressing 'F8KEY' when booting time to Enter SAFE Mode...After Entering Safe mode You can Uninstall newly installed Softwares.It might be reason for Clash in windows system Boot file.
Let me know if you need Further assistance...Hope this Helps...Thanks for Connecting FixYa,,,
Apr 15, 2011 | Office Equipment & Supplies
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
My system restart problem
Sounds like a hardware or heat issue. In safe mode your computer is using just minimum resources. Check the temp of your processor, and make sure all cooling fans are running. You can enter bios and check hardware monitor to see the temps.
Apr 25, 2009 | Microsoft Windows XP Professional With...
Computer crash and restart
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Jan 28, 2009 | Computers & Internet
Computer keeps rebooting every 30 seconds. Whats Wrong?
Your computer could be infected. Press F8 a couple of times when you first turn on your computer when you see the HP logo. You will get whats called an advanced startup menu. Choose Last Known Good Configuration. If windows loads successfully, scan your computer with Anti-Virus and Anti-Spyware programs to remove infections. If windows does not load, do the above again but this time choose Disable Automatic Restart. By choosing Disable Automatic Restart the system will give you a blue screen. Write down that information from the blue screen and post it back on here.
Nov 12, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Microsoft Windows XP Professional Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
