Question about Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Can not pick up line on incoming calls from any extension, i can only answer calls from the first phone plugged in?
  • Panasonic Master
  • 2,460 Answers
Yep, out of the box, that's what it does.
Did you do any programming? By default, the phones have SCO's mapped to each of the buttons, so you should be able to access all lines on all phones. Now, ICD groups control how they ring, and by default they don't exist.
Since your 76xx phone could be plugged into any of 5 phone systems running any version of the software, it would be best to contact your installer for programming.
Or did this come from the internet?
Carl
Posted on Sep 08, 2008
INCOMING CALLS SHOW "601 DAY" ON THE PANASONIC KX-T7630, THE CALL DISPLAY IS GONE, HOW DO I FIX THIS?
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
Nov 15, 2016 | Panasonic KX-T7630 Corded Phone
How do I connect a background music source to Panasonic KX-T7630 phones?
The Music On Hold (MOH) is not connected on the KX-T7630 Phone but rather to the phone system. You will need to get an extension from the phone system and connect it to the KX-TVM50/200 Voice Processing System (VPS). Incoming calls are then answered by the extension connected to the VPS ... i sugest you get a Tech to help you with setup or get an online programmer to guide you on hardware setup and he does the programming for you.
May 27, 2014 | Panasonic KX-T7630 Corded Phone
On the Panasonic KX-T7633, how can you answer a call on extension 101 that is actually ringing/incoming on extension 103?
A couple of ways, the easiest is to dial *41103 on the intercom. *40 may also work, but it picks up any ringing outside line.
Carl
Jul 20, 2011 | Panasonic KX-T7633 Corded Phone
Is it possible to turn up the volume on incoming calls
Your Panasonic dealer can access the special programming to increase the volume to all extensions. That would mean ALL lines to ALL extensions. You might want to keep a log of incoming calls to see if it really is all lines before you take that solution. It may be just a single bad line.
Carl
Aug 04, 2010 | Panasonic KX-T7630 Corded Phone
Answering
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing.
Thank you.
Mar 25, 2010 | Panasonic KX-T7730 Corded Phone
When I try to hook a second kx-t7630 to another (parallel) I can make outgoing calls but cannot answer them.
I'm guessing you're using the Digital XDP port. Each of the phones has an extension and that 2nd extension number has to be added to the ICD group as a phone for the lines to blink or ring on the 2nd phone.
It requires system programming.
Carl
Sep 24, 2009 | Panasonic KX-T7630 Corded Phone
I attached one t7630 to another (parallel). The
Parallel is just a method of connecting phones. It has its own set of programming, both extension number, class of service, and ringing.
If you have access to system programming, you can add this phone to an ICD group with the other extensions. If not, you'll have to get in touch with your installer/dealer to make the changes.
Carl
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Taking the call from the extension
Try *41 followed by extension number
OR *40 followed by group number eg 00 or 01
Jan 07, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
294 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
