Question about Conairphone CID 244
How do you store & retrieve phone numbers on a conairphone sw324wcs?
2 Suggested Answers
SOURCE:
SOURCE: ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Posted on Jul 15, 2007
Require instructions to set the memory on conairphone PR6202WCS
l found these manuals for Conair phones, and one of them may, hopefully, help:
http://www.retrevo.com/samples/Conairphone-manuals.html
May 27, 2011 | Cell Phones
Tip
Numbers are stored on my phone how can i retrieve them
If you have a phone that is broken, a screen that is not working or just want to move phone numbers to a new phone, this article will help you do that.
If your phone numbers are stored on a external SD card you can plug the SD card into your computer or another phone to retrieve the numbers. You will need a SD card reader or a computer that already has one. Some newer laptops have a SD card reader. You can find external SD card readers at local electronics stores. I recommend visiting www.newegg.com(card reader examples) for your hardware needs. I have used this site extensively and the customer service, pricing and products are A+.
If your numbers are stored on the SIM card, you can move the SIM card to a new compatible phone. The SIM card generally contains your phone number and other account information from the phone carrier, however, you can use it to store phone contacts as well.
Your local phone dealer like AT&T or Verizon may be able to help you retrieve the data or move it to a new phone compatible phone.
Regards,
G33k
on May 24, 2011 | Cell Phones
I have no screen and my numbers are stored on my phone how can i retrieve them with no screen
If they are stored on the phone itself(SIM card) you can transfer the SIM to a new compatible phone.
Otherwise, you may have to take the phone into your local phone dealer like AT&T or Verizon and they may be able to help you retrieve the data.
Regards,
G33k
May 20, 2011 | Cell Phones
How to replace different numbers in the memory. Conair 13 memory speakerphone.
1) Press "STORE"
2) Dial the number you wish to save in a memory location.
3) Press either the "Priority Memory" keys (M1, M2, M3) or a keypad
number (0 through 9) to save the dialed number in that location.
To dial a stored number, if it's a "Priority Memory" number, just
press the key (M1, M2, or M3). If it's a number stored in 0 through
9, press "MEMORY", then the desired number key.
Here's a link to a manual for a ConairPhone memory phone:
http://www.conairphone.com/IBs/feature_telephone/sw6404.pdf
Mar 19, 2009 | Conair Lands Phones
Set Date and Time or User Manual
I found a website that suites you well it is: http://www.conairphone.com/Pages/quick_reference_pages/CID100_qrt.html
This has step by step instructions on how to do everything to your phone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 01, 2007 | Conair CID 100 Conairphone
Jul 12, 2007 | Conair SW324WCS Corded Phone
Storing numbers in memory
Call conairphone, they will tell you over the phone how to sotre numbers. You can find their number by doing an online search. If you have an old model phone follow these steps. You have to make sure your batteries are working. Leave phone in cradle - press and release store button - dial the number - press and release store button again - press the button you want your number stored.
May 07, 2007 | Conairphone CID 244
Deleting messages
You can download a copy of the user's manual here: http://www.conairphone.com/IBs/digital_answering_systems/tad1212.pdf
Apr 17, 2007 | Conair TAD 1212W Digital Answering Machine
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Mar 15, 2007 | Conairphone CID 244
Conairphone CID 244 Logo
134 people viewed this question
Top Conair Lands Phones Experts
Marvin
Marvin
k24674
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
