Question about Thomson 21DC320 21" TV
THOMSON - QUADRA 21''(21MT62IN)
On my tv , there is a permanent PI written on the screen and after which the remote of the tv has stopped working. kindly solve my problem asap.
thanks
sarika
  • Anonymous Oct 14, 2008
    Same problem here
Were you able to get the problem solved Even I have the same problem
Posted on Jun 19, 2010
Hello, if he/it pleases you ,je I am maintenancier and I need Diagrams or Schemas
of the television Thomson Quadra 21 " models 55 MT 21VT
thank !
Posted on Oct 25, 2009
Even i have a same problem
Posted on Dec 24, 2011
Thomson tv
Check its audio setting at its sound setting menu first. If audio is muted, there will be no sound output. Check the speakers. If they are too OK, check and replace damaged component/s at its audio output stage circuit. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 08, 2013 | Thomson 29DM400 29" TV
Tv thomson black screen
this a problem from Raster, coming from HV flyback, rectifiier, horizontal output, and circuit from HV. repair.or go to the repair shop TV for fix it.
However you must reset the code, download from www.fitness.manualsonline. com or memorex.com or www. remotecodelist.com and try it again.
God bless you
Jul 22, 2012 | Thomson RCT311DA1 Remote Control
How to program my quadra surf remote to hitatchi television
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 15, 2012 | Thomson 14MG135 14" TV
Lost my TV remote but have a diferent thomson remote .Should the secondone work on my tv
You can find inexpensive universal remotes that work with Thomson here: http://www.electronix.com/remote-controls-c-9.html
May 25, 2011 | Thomson Televison & Video
Red colour on screen
if crt pic tube magnitized need to degausse with coil
Jun 01, 2010 | Thomson 21DC320 21" TV
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
28VK25US Thomson tv, install menu comes up each time switched on.
My Thompson TV only works on av3 thus I cannot get discs to
accept as this has to be on av1 how do I tune in?
Jan 28, 2010 | Thomson 28VK25US TV
Thomson top up tv remote codes
need sequence to tune in remote controller
May 13, 2008 | Televison & Video
Thomson tv, model quadra 21
reset the memory of your tv,or the EEPROM.to reset it just simply unplug the unit,then press together the menu and the vol+ buttons,then press the power switch,when its on,release together the from pressing menu and vol+
Oct 18, 2007 | Thomson 21DC320 21" TV
Thomson 21DC320 21" TV Logo
1,118 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
