10 yr old TOshiba rear projection ultravision 55inch screen shrinks vertically (top to bottom about 15 inches) when first started, when hit it sometimes goes back to full screen.
  • pphilt8 Sep 09, 2008
    model 50UX27K V 7b014046 Hitachi Ultravision is model # so what is part number of vertical IC? how do I communicate with you?
    Comment by pphilt8, posted on Sep 09, 2008
    Genius:
  • 1,268 Answers
The problem there is an internal component on the circuit board might be burned like resistors, transistors or capacitors. Try to open the casing of your TV and visually check eny visible burned electronic piece. If you found one, you can just replace it. If you have no idea on how to solder and desolder electronic parts, better have it repaired by a TV technician.
Posted on Sep 09, 2008
  • 97 Answers
Get a service man to get the vertical IC replaced. It should have blown.
    President:
  • 1,952 Answers
It may be problem in mother board electronic item...pls check whether it works in proper way by usin multimeter..
Posted on Sep 08, 2008
  • 4,234 Answers
This sounds like poor solder connections at the vertical IC. If this is corrected soon, there will be no other problems. If left as is, the IC will eventually fail. If you can solder, you can fix this yourself. Look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. If you post the model number, I can give you the exact part marking.
Kep me posted.
Dan
  • ABRsvcs Sep 10, 2008
    I can't find the IC listing for your model at this time. If you look in the back of hte set for a small flat IC attached to a heatsink with about 11 pins and post the marking on the IC, I'll confirm that it is the correct one. You may have to remove the clamp off of the IC to read the marks.
    Dan
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
What's your problem?40-42 inch Theater View Toshiba TV, Date on TV is June 1999. Picture slowly started shrinking from up and down. Model no. TZ50V51 Serial no. 77988872 chasis no. 9951
you're experiencing a vertical deflection issue and will most likely need to replace the deflection board. You can get a deflection board for your model from www.tvrepairworld.com
Oct 18, 2011 | Toshiba 57H81 57" Rear Projection...
Picture shrinks to only show top half
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
May 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
TV screen shrinking from top to bottom.
My Dearest, j30;
It sounds like you have a problem in the 9 volt circuit which feeds the vertical output ciruit; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
This is not a repair that a novice should try, but if you call a factory authorized service center and have them come out and give you an estimate; AND tell them what the problem is, you will look know what you are talking about!
Aug 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Hitachi Ultravision LCD Rear Projection
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Jun 24, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Shrinking screen
the tv is having a vertical problem have a tech look at it for possible repair.the problem is intermittent therefore it could be that it has cold solder or the vertical ic needs to be replaced along with spme caps that are not filtering the voltage properly,good luck.
Apr 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
