I'm having trouble using the Print Screen Function. I bought my keyboard off of Ebay and have no instructions on how to make that function work. I have tried multiple combinations such as num-Lock CNTRL/F11, but cannot get it to function. Can you tell me the keystrokes to use?
  • 258 Answers
Ok depending what your trying to print you could right click on the screen then select print or print preview, there is obviously no print screen button?, what are you having trouble trying to print?
Posted on Sep 08, 2008
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
Number pad on wireless keyboard not working
turn on your numeric lock............can be enabled in BIOS, should be same as on corded type.... The Print Screen key does not work. Try the following:
  • The Print Screen key copies an image of the screen to the clipboard (not the printer). To use the image, start an application that uses graphics, such as Microsoft Paint, and use the Paste function.
  • If your keyboard has an F Lock key, press it to toggle between Function key modes. On some keyboards, the Print Screen key only works if F Lock is on.
Good success, meder's tv service
Jul 17, 2012 | Computers & Internet
I am using Lenovo Y550 laptop. I want to use the Print Screen command but unfortunately there is no Print Screen key in this laptop. Could anyone please help me with regards to this issue. Thanks.
Most laptops do not have a dedicated print screen key, but instead have a function key (lower left of the keyboard, with some abbreviation of the word "function" on a key in a different color than the writing on the rest of the keys). Once you find the function key, look at the writing on the other keys that is the same color as the writing on the function key. One of those "other color" labels will be for print screen, and to use it, you hold down the function key at the same time as you push whatever key says print screen in the other color.
Jun 10, 2011 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
Please tell me how to Print screen on a Microsoft ARC keyboard. There is a print screen above the Home button in blue but NO function button?
Actually there is no separate PrtScn key on the Arc keyboard. The print screen is a Function key combo.
Fn + Home
To capture the active window only it is Alt + Fn + Home
Apr 04, 2011 | Microsoft DA900013 Keyboard
I bought a gateway online on ebay. Cant get keyboard light to light up. I have tried to use function keys. Dont work. Do i need to replace keyboard. Are the lights even located in...
no if you bought it on ebay more likely than not the correct keyboard drivers are not installed are the previous user wipped it simply search for the correct driver download it open control panel> device manager> find keyboard driver and update it to the correct one
Feb 27, 2011 | Gateway 7330GZ Notebook
How do i use the prt scr button
Whatever happened to the Print Screen key??
If you did computers back in the 80's (DOS days) you probably remember using the Print Screen key on your keyboard to print a copy of whatever was on the monitor screen at that time to your printer. It wasn't used that much because back in those days it took forever for a dot matrix printer to print out the entire monitor screen. However, it came in handy once and awhile.
Microsoft has turned the key into into a "Snapshot key" which, as that term implies, takes a snapshot of the monitor screen.
After taking the snapshot, in XP simply click on Start, All Programs, Accessories and Paint. Then click on Edit followed by Paste and Voila! There's your screen snapshot in living color staring you in the face!
Now you can use "Save As" and save it with a .jpg/tif extension (etc.) and/or send it to your printer using File, Print.
If your keyboard Print Screen key performs more than one function you will have to experiment a little to get it the key to perform the Print Screen Function. Try holding down the ALT, SHIFT, or CTRL key (or any "special" keys unique to your keyboard) when you hit the Print Screen key in order to get the key to perform its Print Screen function.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 23, 2011 | Compaq 135227-001 Keyboard
I am enlish and have bought a spanish keyboard
if you can navigate to the control panel, regional settings. you can change the keyboard layout. but physically changing the keys is difficult. see if you can pick up an english keyboard on ebay and have it fitted
Aug 02, 2010 | Acer Aspire One PC Notebook
I can't find the "FN" key on my wireless logitech S 510 keyboard
buy another keyboard which have FN key... theres a kind of keyboard that are not using FN key...
Jun 16, 2009 | Logitech S 510 (967555) (DH967555)...
Using the print screen button
When you use the Alt Print Screen button then you need to place it onto a word document in order to print it. Open up word and select to paste the frame into your word document and then print it out.
Jul 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Insert or over-type feature
I have the Microsoft Comfort Keyboard and it has a "F lock" key. This key has to be set on "Off" to let it know that I want to use the Print Screen function versus the Insert function on the same key. May be your keyboard is the same way.
May 03, 2008 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
