Question about Panasonic PT-53X54 53" Rear Projection HDTV-Ready Television
PT53WX54J Shut Off LED blinks 3 times
Hello I have a Panasonic PT53WX54J rear projection tv.I've had it since 2004 with no problems. Today it just shut itself off with no prior warning or picture distortion. I tried to power it back on and it clicks...but when it gets to the second click which usually turns on the picture nothing happens and the power LED blinks 3 times stops then blinks 3 times again and again. I took the back off and cleaned out the dust with compressed air and a vacuum.Tried again with no results. I read the article on the convergance amplifiers at chris palmers blogspot. Is there any other reason to get the 3 blinks or could I be certain that the convergance ic's are bad? Any other tests I can try?
** Another thing I noticed is the power LED does not glow as brightly when its trying to power up?
A little discoloration on resitor at R7013 and is it normal for what looks to be wax around the bottom of the picture tube and below on the circuit board?
  • 5 more comments
  • Anonymous Oct 24, 2008
    Smae problem for me however it is R0714 and it glows hot before the TV shuts down. I can see this very well in the dark.
  • Anonymous Oct 28, 2008
    I have the SAME i send to get fixed or toss it out!
  • Anonymous Nov 28, 2008
    Exact same issue...need solution
  • Anonymous Dec 19, 2008
    same problem
  • jpl4 Feb 25, 2009
    wont sar but beeps 5-6 times and turns off
  • nova71977 May 10, 2009
    the picture became a strip down the middle of bright colors and then turned off on its own. when i unplugged it and plugged it back in it beeped a bunch of time and then the beep died and the power light on the front blinks 5 times stops and then repeats.
  • psflores May 14, 2009
    "PT53WX54J Shut Off LED blinks 3 times" problem
  • 10,594 Answers
3 blinks LED shows problem with convergence out ICs that either bad or not getting supplied volts from supply board to function properly.
Posted on Jul 23, 2009
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV won't turn on. (Panasonic 1080i HDTV)
thats the error for the convergence ICs You will need two STK392-110 Convergence ICs you can get replacements at the following link.
Apr 21, 2009 | Televison & Video
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX54J shut off - LED blinks 3x
Your convergence ICs need to be changed. 3 Blinks is a convergence error. I can post a link where you can get new ICs and they include free instructions with pictures so you can do the repair yourself, they also offer instant messaging with a tech while your doing the repair thats a free service when you but their replacement parts. Let me know if you would like the link.
Apr 04, 2008 | Televison & Video
Panasonic PT-53X54 53" Rear Projection HDTV-Ready Television Logo
1,327 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
