Question about Philips GoGear HDD6330 MP3 Player
Hi my mp3 6330 wont turn on, it shows the screen light with options like menu and forwrd, reverse buttons, but nothing moves etc,, where can i find the Reset key as i have seen someone instructed for that
  • 8,596 Answers
There is a lock switch - make sure it is not engaged. The reset is power on AND volume + at the same time.
Posted on Sep 14, 2008
In my nokia N70, call is getting disconnected and loud speaker activated, music player opens and 4 numbers displayed on the screen every time.
Hi! nothing to worry! here are the simple steps to solve ur problems!
first of all move to settings on ur phone menu! then click phone and call option then hit call option here change option for loudspeaker, volume, call disconnecting, etc after these ur first problem solved! based on ur question i suggest u to set default settings to ur phone !these are simple it appears on phone menu->settings->phone->phone original settings->it asks password if u already assign or else simply try to enter 12345 thats it . it ask u to restart phone! don't worry ur data wont loss! it will be safe! still u facing problem means ! try to format ur phone! its simple u wont waste money! simply follow these: remove ur mamory card, try to backup messages, contacts and media, etc! then turn off phone, renove sim card! then press with ur hand with the following buttons *,3, dial for five to 10 seconds then press power button ! phone ask u to format or not press format! then thats it ur phone formated to original state at the time of purchase! try to use antivirus to protect ur phone, avoid bluetooth to reduce such type of risks..! thats it! hope so u understand! plz rate if u like! Thank U!
Jun 08, 2011 | Nokia N70 Cellular Phone
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
Can u give me instructions on how to forwrd a message to others, wher to find the sent msges and draft msge. thanks
If you want to forward a message from history, you can press and hold the message to bring up the forward option.
Tap on the phone the up arrow and then Messages. The All messages screen opens, showing all your sent and received messages neatly grouped into conversations by contact name or phone number.
On the All messages screen, press MENU, and then tap Drafts. Tap the message to edit it.
Dec 23, 2010 | HTC Wildfire Cell Phone
I have a 2003 Ford Windstar Sport van. I got in it to go uptown and it won't shift from park into reverse. I turned the wheels to see if that would help and nothing. The emergency brake isn't on. There are...
brake lights come on? if the brake pedel switch isnt working it wont let you out of park. also a steep hill can make it hard to move out of park.
Mar 16, 2010 | 2004 Ford Windstar
The screen light on my phone doesnt work
More than likely, you've turned the back light off all together. Go into the menu, and display settings and find the backlight options.
If it's set to 'on' and to stay on for at least 3 seconds, yet nothing works: turn your phone off and then back on again. If still nothing, take the battery out, put it back in and start it up again.
If there's still no backlight, contact your supplier or the store you bought it from.
Jul 25, 2009 | Motorola Mobility V265
D580 camera black screen what is the problem
Press the menu button and navigate to screen option and make sure it is on. If nothing shows up when you press the menu button, the screen may be defective.
May 31, 2009 | GE E1040 Digital Camera
Rca rp5011a
Regarding RCA RP5011A
Turn on = Play + Menu (at the same time)
Turn off = Stop (will revert to just clock)
Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options
Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file.
Take batteries out to quickly reset recorder (will not lose saved files)
Jun 06, 2008 | RCA RP5011 Digital Voice Recorder
Screen wont show boot screen
fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Dec 08, 2007 | Dell Latitude C400 Notebook
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Philips GoGear HDD6330 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
