Question about DeLonghi EC140 Espresso Machine
Won't dispense water into espresso - DeLonghi EC140 Espresso Machine
  • 868 Answers
The pump is not working and finding one is going to be a problem before you can fix this.Most parts such as this are over priced and repairs over exceed the value of a new machine.
Posted on Sep 08, 2008
Water is not dispensing
does the machine ask you to fill water? If it does check to see if the float is secure and still inside of the water dispenser. It's a small compartment inside the water dispenser that houses a float with a cap to seal it in.
Oct 03, 2013 | Miele CVA615 Espresso Machine
New out of the box. won't dispence water to make espresso
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EC155 Espresso Machine
Hello! my 102534 gaggia esppresso machine has liquid/espresso dispensing after the 'espresso dispenser' has been turned off. if i turn the entire unit off, it does eventually stop. i've have...
HI JULIE,....MAKE SURE YOU ARE NOT FILLING THE WATER DISPENSER PAST IT'S OVER-FLOW...THERE IS A HOLE TOWARDS THE TOP...YOU DO NOT WANT TO FILL PAST.
HOPE THIS HELPS!
Sep 03, 2011 | Gaggia 102534 Espresso-Color...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Grouphead not dispensing water
Remove the shower screen and press button to brew, if water flows the the holes in the screw/diffuser is blocked, if water does not flow then the blockage is at the solenoid or within the group head chamber. This problem I have notice when someone brewed without the shower and screw in place.
Jun 29, 2009 | La Marzocco Linea Series Group 3 Espresso...
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
No coffee dispensed and no water comes out when Rinse selected
1st use cleaning tablets used for brew unit. and go on cleaning procedur.
2-the sound you hear i think is only motor of
grinding
thank you
Mar 24, 2009 | Miele CVA615 Espresso Machine
Clogged Dispensers
Sounds like a burst water line inside, if you made sure there is water available, and you hear it pumping. Either that or a solenoid valve is not activating. Must remove unit and pull the cover to investigate.
Jan 10, 2008 | Miele CVA615 Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
DeLonghi EC140 Espresso Machine Logo
432 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
