Heating & Cooling Logo
Posted on Aug 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to re-program White/Rodgers thermostat # 1E78-144.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 127 Answers
  • Posted on Aug 24, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
127
Questions
0
Helped
31132
Points
164
The model number given is a non programmable digital thermostat.
2answers
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
1helpful
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Hello I need program instructions for a white-rodgers thermostat that has these numbers: 156 3069B. Can you help me?thanks Linda
please call the homeowner tech line at 18002842925.
or check the TYPE NUMBER of the thermostat usually it starts with 1FXX-XXX. When you have that handy visit the website of White- Rodgers, just put the type number on the search cross reference box it will lead you the way to download the instruction manual online.
I need instructions for programming a Blue
Page 7 Programming
visit this website Link: http://www.emersonclimate.com/Documents/White-Rodgers/0037-6753.pdf
If you need futher help call hometechline 18002842925.
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
2answers
How do i program my 1F82-261 thermostat?
see link below
http://www.white-rodgers.com/wrdhom/common/ptech/thermo/80_Series_faq.htm#23
1helpful
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Top Heating & Cooling Experts
Paul Carew
john h
