Question about Alpine Car Audio & Video
Setting up alpine amp
I have an alpine amp MRH-F255 for my car with no manual.How do i set it up properly because i am only getting a pop noise when i am suppose to be getting a bass sound from my 12" sub?
  • 113 Answers
Check for proper ground also main12v and ignition
Posted on Sep 08, 2008
Can a alpine mrh-f 254 4 channel amp be bridged to one channel
You can combine two channels into one, but you can't combine four channels into one. The best you can do is bridge it down to two channels.
Aug 02, 2015 | Alpine Car Audio & Video
Need wireing harrness for analpine mrh-f255
u come go online an get one or order one from a system store .
Jun 08, 2011 | Alpine Car Audio & Video
When i start my car i hear a noise from my car cd player
1- If it's a pop up noise, reduce you amp gain control.
2- If it's hum or alternator noise, use a small noise filter. It can be found anywhere (radio shack, alpine, pioneer) usually it costs around $5 to $20 depending on size & ampere.
Sep 20, 2009 | Pioneer CDX-P656 CD Changer
Bought a Alpine PDX1.1000. 1 - 8v issue
Hello rsnyder_223,
As long as the gain is adjusted properly for the input, there should be no problems with the amp.
The head unit preamp output is probably a little low or there is too much voltage drop on the RCA's. It doesn't take much of a drop when you are working with such a low level to begin with. That's one reason that Alpine gives you the option to select an input level.
It's also possible that the input sensitivity of the Alpine is slightly high. Electronic components usually have a nominal value and their actual value can range up to 20% from that nominal. But again, you have a gain adjustment to insure that the amp is not overdriven. Make sure that it's set so there's no distortion and you should be OK.
Hope this helps.
Aug 23, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Volume issue with Alpine CDA-7839 and Soundstream Continuum
Interesting that you have a Soundstream "The Continuum" amplifier. This is limited edition of the Reference 705 amp produced with a polished aluminum (not chrome) case. You have a very hi quality - Old School - amp.
Properly installed this amp should produce more than ample volume levels and certainly far more than a stock unit.
Because the Alpine head unit provides sufficient voltage to drive the amp, it is likely either the wiring, or, the way you have it set up.
The amp has a large internal capacitor bank and for proper operation, this amp must be connected directly to your car battery, prefereably with 4 AWG. (The amp is made with 4 AWG power connections.) Use high quality speaker wire run directly from each speaker to the amp.
If you have done the above, then it is probably the way you have it set up. The amp is sophisticated with many configuration options. Do not change any switch settings while the amp is playing. Ensure you have the appropriate inputs and crossover selected. Check the gain settings.
Jul 12, 2009 | Alpine Car Audio & Video
CDA-7894 ALPINE CD CAR STEREO NO SOUND JUST POPS
ic needs changeing on the menu if its had an amp added the stereo swiches over u can do it manualy i c in the menu or connect an amp...
Apr 18, 2008 | Alpine CDA-7894 CD Player
Car Audio & Video Logo
396 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
