RED CRT MY PHILIPS HDTV'S RED CRT SEEM TO HAVE A PROBLEM, COULD THAT BE REPLACED? WHERE CAN I GET THIS PART?
  • 49 Answers
Pls specify the fault..no red?weak red?poor color...it will make us analyze the fault easier.
Posted on Oct 14, 2008
Dptv335 model number#60pp9363H/17SAM Mode Green Convergence
Your Green CRT is getting Mold in the glycol. This will get worse. You need to drain the glycol out of the crt and clean, then apply new glycol to the crt. You should do the blue one also, because it will go next. The Red can can be left alone.
Mar 20, 2013 | Philips 60PP9363 60" Rear Projection...
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
I have an old model philips HDTV. Instead of just showing the words it has a green letter and red letter next to eachother is there a way I can fix this without having to take it in
If a large rear projection with 3d like picture---go into menu with the original remote and select convergence---if it adjusts you can do that and be good to go----if it will not adjust in some area of the screen it needs the convergence chips (Likely stk-392-120's replaced--there are two of them).
SD TECH
Apr 29, 2012 | Philips Televison & Video
I have a Philips 60"
The set will need a convergence repair kit. Or to turn the red CRT off you can turn the screens down on the red CRT untill it shuts off, But the set will have a very blue or green picture and will not be very good to watch. A convergence repair kit is the best way. You can get the repair kit with instructions from www.tvrepairworld.com
May 05, 2011 | Philips 60PP9202 60" Rear Projection...
The red crt on my 55PW9363/17F keeps flashing and clicking i turn it down till its off and it stops. any suggestions?
sounds like the RED CRT Drive board has an issue. Most likely solder issues on the CRT socket on that board. If the board appears fine the CRT itself would be suspect then.
Jul 22, 2010 | Philips 55PW9363 55" Rear Projection...
Red CRT Socket....Part # ???
The part # is 313503710081 this number is good for all 3 picture tubes.
Jan 30, 2009 | Philips 55PW9363 55" Rear Projection...
Red crt tube
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Oct 01, 2008 | Philips 60PP9202 60" Rear Projection...
Philips projection screen 55pp9363
HDR LSM ASM is the problem. Philips part number 313503711011. Contact parts store on line at www.partstore.com for part.
Dec 26, 2007 | Philips 55PP9363 55" Rear Projection...
Philips 60" projection screen
It may have a bad blue crt they are know to cause trouble arcing and when they do they damage the LSB board you can buy the board yourslf but if the tube is doing you in it must be replaced too,
Aug 20, 2007 | Philips 51PW9303 51" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
