Question about Frigidaire Affinity ATF7000E Front Load Washer
LOC message on display - Frigidaire - GLTF2940FS0
Three beeps and periodically appearing message 'LOC' on display while turning on Frigidaire - GLTF2940FS0.
Rebooting - turning off for 15 minutes - does not help.
What could be the reason?
AK
  • alkhart Sep 09, 2008
    Dear ngafm
    It is looking like you do know what is the way/methods to fix the problem.
    Even it is just trial and error approach - I would like to know it.
    Can you share ?
  • Anonymous Mar 13, 2009
    solution is to push & hold the 2 buttons above "the lock indication" on the control panel for 3-11 sec. The child safety feature is on, this will turn it off.
You have accidentally locked the machine. Hold the "Options" button and the "Select" button simultaneously for 10-15 seconds and you are goog to go.
Posted on Apr 01, 2009
    Novelist:
  • 166 Answers
The reason will not help cure the problem! you have the top of the line Frigidaire front load washer!
It's worth a service call after all that you spent on this machine.
Knowing why will not get it running!!!!!!!!!!!!!!!!!!!!!!!!!
Hands on service is what you need and only this will solve the issue!
If I was there I could do this for you!
But I can't touch it from here!
Call them Wednesday
Bless You ngafm
Posted on Sep 09, 2008
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
GLTF2940FS0
Good Afternoon Friend,
I understand you want to know how to replace the upper hose to the drum of your Frigidaire washer, model# GLTF2940FS0. Typically, this is not a do it yourself repair, as there are no step by step instructions. I suggest either contacting the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Washing Machines
Error message LOC
Do the following:
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and LOC is displayed. To cancel, press and hold the lock symbol until LOC is no longer displayed. To put the control into control lock you do the same thing.
God bless you
Sep 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Problem with the Frigidaire PLES389D Electric Kitchen Range I have a frigidaire PLES389ECC. door will not unlock after cleaning. message reads loc
Oven stays locked during cleaning cycle. then it has a preset cooling cycle which is about 2 hours. This is a long period but normal
Jan 22, 2011 | Frigidaire PLES389D Electric Kitchen Range
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Error Message "LOC" Three beeps, won't door lock or start
You may have to remove the lower front panel to get to the tech manual. If the door latch isn't latching though nothing is going to happen.
Jun 15, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire - GLTF2940FS0 -LOC message on display
Peace,
ngafm at your service,
With an error code or loc message the only way to find and to repair this is,
First unplug the washer and wait a ten minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
380 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
