Question about Lexmark X2250 All-In-One InkJet Printer
Computer says there is no ink cartridge
I have a Lexmark X2250 printer. My computer keeps saying that there is no ink cartridge. The first time it did this, I replaced the cartridge because the ink level was very low. This time there is no problem with ink levels. I have tried taking the cartridge out and putting it back in, but it doesn't make any difference. I can't print anything at the moment.
  • 4 more comments
  • agalady Sep 14, 2008
    Computer is suddenly saying that there is no cartridge, when there is one. I have taken it out and put it back, switched everything off anf on again and still not joy. Can anyone help, please?
  • Anonymous Oct 06, 2008
    The same thing is happening to me. I had a low color cartridge then replaced it, now it won't print because it says there is no cartridge. If someone has an answer, please...
  • ian washingt Oct 13, 2008
    No ink cartridge? After switching printer off I get this message so I 'replace' cartridge with new and it goes through motions of printing but will not print.Done usual checks and noresult at all!
  • Anonymous Oct 14, 2008
    same thing happening to me.....changed the ink too.....and still getting same message HELP HELP HELP PLZ !!!!!!!!!!!!!!
  • Anonymous Oct 20, 2008
    Hey guys I have the same problem. If I uninstall the Lexmark software and drivers, then reinstall them, I am able to print, but [B]only once[/B}. If I try to print again, it doesn't recognize the ink cartridge.
  • chrisxhtml Oct 20, 2008
    cartridge.
OK guys, I don't know if this will work for you but it worked for me. Here it is:
  1. Uninstall all Lexmark software from Add/Remove Programs in Control Panel.
  2. Reboot the computer as suggested by the uninstall software
  3. Start the ALL-In-One Installer
Now, the first thing the installer does is load the drivers to your hard drive.
4. When the driver is installed it will ask you what ink cartridges you have. Tell it which ones you have and say they are both brand new (even if one is empty or not new). If it asks you to align the printer or print a test page, say no!
After this is complete, the installer will begin to put in the other software (i.e. fax and scan). It will pause and ask you to click next, but do not do this.
5. Press Ctrl+Alt+Delete, select the installer task and click end task to stop the installation process.
6. When you print for the first time, it may ask you what cartridges you have installed again. Just select the cartridges you have installed select the option from the drop-down boxes that say that both cartridges are new.
Hope it helps since it worked for me. Good Luck
Posted on Oct 20, 2008
    I believe you will need both cartridges installed for this to work, even if one is empty.
2 Suggested Answers
  • 684 Answers
SOURCE: refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on Apr 29, 2009
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
I bought lexmark 2200 all-in-one second hand.I've loaded software twice but still printing blank pages.It says both cartridges are full. Could this info be wrong? I hate to buy new cartridges if printer is...
Is this a genuine lexmark cartridge? If so, please take it out and use a tissue paper to cover the bottom part and give the cartridge a gentle shake.
Then clean away the ink and put it back in.
Aug 15, 2010 | Lexmark X2250 All-In-One InkJet Printer
My lexmark x2250 printer gives me error message no cartridges in machine, even though there are new ones in the machines. What can I do?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 09, 2010 | Lexmark X2250 All-In-One InkJet Printer
My x2250 wont print the ink cartridges are both full what else could be wrong. It just prints blank pages.
Restart both the computer and printer. (Unplug the printer form the wall clearning the print cue.
Print a test page from the printer control panel
(Start button>control panel>printers and faxes>right click>select properties> print test page button)
Now if it prints there, then you have a problem with the program you are printing from. If not then
You have a bad driver (reinstall from the cd)
You have a bad cartridge (remanufactured cartridges or dirty or old or even unused cartridges will result in non functioning machine)
If none of those work, then your printer is flat broken.
Oct 23, 2009 | Lexmark X2250 All-In-One InkJet Printer
Printer produces a poor copy
remove cartridges , take a q-tip w/alcohol and clean out ink ports where they drop ink onto the paprer the ports could be clogged with dry ink , thus preventing the new ink from reaching the paper. after you clean out the ink ports re-install the cartridges, and do alignment proceedures again this time color should be restored
Jul 11, 2009 | Lexmark X2250 All-In-One InkJet Printer
Refill inkcartridge 17 of lexmark x2250 don't work
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
Printer not printing
plz give me laxmark X 2250 printer driver
Jan 18, 2009 | Lexmark X2250 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X2250 All-In-One InkJet Printer Logo
813 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
