Question about Samsung SCX-4725FN All-In-One Laser Printer
I HAD A PAPER JAM. GOT THE PAPER OUT BUT NOW THE PAPER WON'T FEED, JUST KEEPS GETTING JAMED. I BOUGHT IT 7/24/08 IS IT STILL UNDER WARRENTY?
  • sullysd5 Nov 17, 2008
    T he paper won't feed and continually gives a "paper jam, open and close door" message.
No thanks don't need any help
Posted on Sep 10, 2008
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Some abnormal sound comming from the printer showing paper jam inside but no paper jam found
open the printer from the top and see if anything is stuck their.it could be a very small piece of paper or maybe something solid.if it still says that it is jamed then go to the service centre.even if your warrenty has expired
Jun 30, 2010 | Brother DCP 130C All-In-One InkJet Printer
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Paper jam
some times you need to clean the rubber rollers inside the printer with alcohol. this helps them to better grip the paper.
also before you put the paper into the printer you need to fan it really good to separate the papers. otherwise they stick to gether and take more than one at a time. thus , paperjam
Mar 06, 2008 | Epson Stylus Photo R2400 InkJet Printer
Samsung SCX-4725FN All-In-One Laser Printer Logo
303 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
