Question about Panasonic PT-61HX42 61" Rear Projection Television
Panasonic PT-61HX42F turns on, but wont stay on.
My panasonic PT-61HX42F Will Turn on briefly, then shut off and the power light blinks three times. I saw on another similar model that it may be the transformer, Is this the case for mine as well? It gets sound and picture but as soon as the picture comes up it shuts off. Thank you for any help you can offer.
Set is five years old, read posted suggestion for repair, is it worthwhile?? get good hi-def picture when working although picture settings are almost maxed out (contrast,sharpen etc) and when first turned on there is horizontal "jitter" which clears away after 2 minutes or so
Posted on Sep 18, 2008
You need to change the stk 392-110 (2 ic ) and some resistor around the area ok
I have a Panasonic PT-D5500U. We replaced the lamp, and then shortly thereafter, whenever we turn on the projector the power lamp goes from green and shuts off and blinks red three times continuously. ...
the problem is a known "bug" by the manufacture, which is due to low temperature issue that's detected by the processor of the projector. it will require a firmware upgrade. i'd recommend getting in contact w/ their tech support.
http://www.panasonic.com/business/projectors/ss_techsupport.asp
Jun 03, 2011 | Panasonic PT-D5600U DLP Projector
My panasonic pt-53tw53 wont turn on. The power light blinks 3 times then pause then three times....etc. If I unplug the set and plug it back in, it will work again but just for a short time, then shuts...
The 3 blink error is the convergence circuits need repair. The Panasonic repair kit PT53WX53 convergence repair kit is the correct kit for your model. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with instructions.
Sep 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Power wont stay on light blinks 3 times
your convergence ic are short
repair about 350
May 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-61HX42 61" Rear Projection Television Logo
243 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
