Question about D-Link Air Xpert DI-774 (DWL-774) Wireless Router
IP Address How do I change the IP address on my wireless router?
    Novelist:
    Scholar:
  • 123 Answers
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin and the password is blank (nothing). Click OK. Step 3 Click on the Home tab then click LAN to the left. Step 4 Next to IP Address enter the new IP address. Next to Subnet Mask enter the correct subnet mask for the IP address entered. Enter a Local Domain Name if applicable. Step 5 Click Apply and then click Continue to save the settings.
Posted on Feb 16, 2006
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
How can I change my routers IP address?
You can assign Different Ip-address manually,Or use the Proxy to change the ip-address,by hiding the Original Ip-address or contact the ISP get the Dynamic Ip-address and Change the Ip-address,You can check the Ip-address at here
http://www.ip-details.com/
Jan 23, 2011 | D-Link AirPlus DI-524 Wireless Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
IP Address
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
D-Link Air Xpert DI-774 (DWL-774) Wireless Router Logo
98 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
