Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Kenmore 27 refrigerator flashing "de" on front panel
I have a 1989 refrigerator from Sears, and I think it finally may be on its way out.  Tonight it is flashing de on the front panel---defrost.  BUT what does THAT mean?
  • Craig Ranch Sep 09, 2008
    Thanks drcool...but what if it's CONTINUALLY flashing. I guess I forgot to add that word! Any ideas? The manual is LONG GONE.
    It just started flashing the "dE" two days ago...although everything is cold, in both the freezer and fridge. THANKS for the help!!!
  • 958 Answers
It is defrosting, meaning its a self defrost refrigerator and it would defrost the evaporator coil so that the ice would not build up and block the air passing it.
it normally happens every 8 hours if it is a mechanical timer, or as needed if it is an electronic timer.
tnx 4 using fixya,
Posted on Sep 08, 2008
  • francis rivero Sep 09, 2008
    how long has it been flashing continuously? as in forever? unless you unplug it?
    normally defrosting takes about 30 - 45 minutes only...if its more than that and the coldness would disappear then that is an error code and not a defrosting code.
    tnx again,
  • francis rivero Sep 10, 2008
    what is the make and model number. i'll try to look around and see if i could help further.
    as long as it is still working ok then that's fine.
    tnx again
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ... > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Why freezer doesnt turn on
If it is a frost free model, the defrost timer could be stalled in defrost. Other than that the thermostat could be the problem.
Jul 16, 2014 | Kenmore Refrigerator Freezer Shelf 13 5/8...
Ice maker does not work. Ice maker controlpanel light flashes twice
Sears or Kenmore is only a name placed on someone elses product. They make it near to impossible to crack the model number code unless you could look around the frame of the door or go to this link=> Appliance Model Number Locations bear with me as I am stil adding information to the page tonight. The answer is in the Sears Model Number for example 321.65987 The first three numbers are who made the refrigerator. After that the number is model and features all in that string of numbers. I can help you or anyonee but the numbers will need to be located anyway. And knowing sears they will not be cheap on a service call. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services,
Thanks, Sea Breeze
Mar 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side 106.55522400 Fridge side is icing milk and eggs.
This refrigerator I have studied for about an hour. There are 2 possibilities. First is part number 2188819 Thermistor and the second is the control board. You did not mention any changes in the digital reading on the control panel so I think it would be worth changing the thermistor. I don't know how old your model is but the price for the control board is very high. The thermistor acts as a thermostat probe and signals to the control board what the temperature are. It's a Whirlpool part so I think that is the brand name before Sears put Kenmore on the front. If you should need me let me know. I'm even in shock at the price of the control board part number 8201660
Nov 20, 2009 | Kenmore Refrigerators
Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Aug 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Jun 01, 2009 | Refrigerators
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Lights on Front Panel Flashing
Another posibility is the door lock switch is broken. When you open the door, on the middle right hand side there should be a small pin sticking out from the washer that the door pushes on.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
258 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
