Question about Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply
Computer doesn't come on.
The only lights that come on are one green one on the motherboard and the one on the power button. The four little lights on the back do not come on, no fan, nothing.
Would this be the power supply, motherboard, or something else?
  • 1 more comment
  • mtennant Oct 09, 2008
    What does the FixYa headline "Dell Dimension 4400 Power Supply ** FREE **" mean?
  • aweaver414 Dec 08, 2008
    same issues on my Demension 4400, flea light is on, no fans, no hard drive start, no bios beeps, just quiet high pitched sound from power supply.
  • Dick
    Dick May 11, 2010
    There is no way to tell for sure without further testing. Replace the memory one piece at a time. Reseat all components you can and try again.
Easy check is: power the system off. Unplug the power supply from the outlet. Hold the power on button in for at least 10 seconds. Remove the CMOS battery. Reconnect the power supply to power. Attempt to power up. See what happens. If it comes up and asks for you to set config, power down, unplug the power supply and hold the power on button for 10 secs. Replace the CMOS battery with a new one (CR2032 button battery...about $5 for 2 in the Wal-Mart photo dept) and power on. The reason for the repetition is to reset the BIOS.
Posted on Jan 22, 2010
How do I re-conect the power on and off switch to the motherboard?
They should be labeled. The Power switch plug should say pwr. The Hard Drive Led should say hdd, etc. Look on the motherboard for the inscribed label.
May 23, 2012 | Computers & Internet
My hp pavilion 734n wont power up
Open the case and ground yourself then:
1. Make sure all your expansion cards are seated well.
2. Make sure all your power plugs are ALL seated and seated well.
3. Make sure your RAM is seated well.
4. Make sure your front panel plugs are seated well and in the correct
spots.
(Basically make sure something above didn't come loose.)
5. Test the power supply or get it tested at a computer shop if none of
the above fixes it. Just because the green light comes on doesn't
mean it's not dead or dying.
6. Replace the CMOS Battery. (This is rare to stop a boot but it does
happen)
7. If none of the above reveals a solution then your motherboard is dead.
Good Luck!
May 17, 2012 | HP Computers & Internet
Green light on. computer wont turn on
Unfortunately, if the light is on, but the computer won't power on, it means one of two things. Either the power cord is broken in some way and no long sufficient to power the computer, OR the motherboard is dead. You can try to purchase a universal cable from Best Buy for instance, and then return it if it doesn't solve your problem. A motherboard repair would be best done through Acer themselves, although, it can cost over $300.
Aug 23, 2011 | Acer Aspire 5735 Notebook
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I have an HP desktop, this morning it will not power on but the light in the back is green. please help...
OK one of Three things, If the light on back is green and blinking it sounds like you have a power supply issue,
You might want to check that the power button on the front is still connected to the switch behind the button, Do this by removing the side cover and looking at the wire, I have one that always pops off and its the same computer,
Third you may have a motherboard issue, One of the easiest ways is to look at the mother board and you will see little caps that look like cans of beans, If they are bulging up or broken then you have a motherboard issue.
I hope its just the button let me know if its not we will figure something out together for you
Sep 10, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Not the power supply!
Hi
To help troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights lites solid green. The power button also lites solid green. If the computer malfunctions, the color and sequence of the diagnostic lights as well as the power button helps identifies the problem.
First, disconnect the power cord and remove all connections (Keyboard, Network, Mouse etc) as well as optional PCI Cards. Connect up the power cord (Monitor as well) and try powering the PC.
Check the diagnostic lights/system lights color and sequence and check the link below for more info (Assuming you have another system that can access internet)
Diagnostic Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
System Lights - http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Reply with lights color and sequence as well as any beep codes and I will respond at best effort.
Mike
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Logo
561 people viewed this question
Alun Cox
