Question about Boss IQ 3KD.1 Car Audio Amplifier
How do i hook up the speakers
How do i hook up 2 1o inch kicker cvr dual voice coils to the boss iq 3kd.1 i need help on wireing up the speakers
  • Anonymous Mar 12, 2009
    do you hook up hot to hot grnd to grnd?
  • 113 Answers
Connect each dual in series then parallel each sub
Posted on Sep 11, 2008
How do you hook up the speaker wire to the ab sub out and what is the best way to hook them up at what ohm
Not sure what you mean by AB but being that this is a monoblock or 1 channel amplifier you can only hook it up 1 way. Verify the polarity from your speaker box. + to + and - to -. As far as your impedance is concerned this amp is stable to 1.5 ohms but for this case we will assume you have two 4 ohm subwoofers. When you parallel these together you will have a total effective load of 2 ohms on the amplifier. This is a stable operating impedance for the amp.
Other impedance options are:
two 8 ohm speakers = 4 ohm load
three 8 ohm speakers = 2.66 ohms
If you have dual voice coil subwoofers then parallel the coils on each sub + to + and - to -. Depending on the impedance of each sub you may then have to wire the individual subwoofers in series. Here is an example.
2 dual voice coils with 4 ohm taps
Each subwoofer with the coils in parallel would be a 2 ohm load if you were to then parallel the two subwoofers together you would have 1 ohm total load on your amp. This is BAD for your amp. Your option is to run the subwoofers in series.
To run the speakers in series is simple. The + from one speaker and the - from the other will be connected to the amp. The other + and - from the speakers will be connected together.
Here is a wiring diagram from kicker.
http://www.kicker.com/dvc_wiring
Jun 11, 2011 | Jl Audio Slash 500/1 Car Audio Amplifier
I need help hooking my kicker cvr 12 to my direct 600 amp
Is the sub a single voice coil or dual???? If its a single, just bridge sub to amp....(+ of one channel and the - of the other) amp should show where to bridge with a diagram near speaker outs. If its a dual voice coil, then run one voice coil to the left channel and one voice coil to the right.
Nov 02, 2010 | Directed 600D Car Audio Amplifier
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
Will my car stereo power 300 watt speakers?
it will power them but it will only push a small amount of wattage to them. something like 45 watts so they won't be very loud but if you run the wires you will hear them. It's beneficial to just invest in an amp you can pick up a 200 watt pretty cheap these days. and you will be much happier with the end result.
Mar 07, 2009 | Boss IQ 3KD.1 Car Audio Amplifier
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Heating up and clipping
A number of things could be wrong. First off, how do you have the 3 subs wired that will actually give you 2 ohms? For instance, if you had 3 single voice coils and they were each 4 ohms You would be sitting around 1.5 ohms. Or if they were dual 4 ohm subs then you could have wired the voice coils in series then the subs in parallel and came up with about 3 ohms. Unless the kickers have an odd impedence then there is no way you have 2 ohms from the subs to match the 2 ohms at the amp. So what I would do is try to match the impedence as well as I could. Also, make sure the amp is well ventilated. do not screw it directly down to a surface, put some 1/4" spacers on the screws so some air flow can get under the amp also. I hope I could help. Good luck
-Andrew Hawkins
Jul 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Oct 05, 2007 | Kicker ZX10001 Car Audio Amplifier
Boss IQ 3KD.1 Car Audio Amplifier Logo
124 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
