Question about Toshiba CF36H50 36" TV
Rowa 686 remote and tv
I have the child lock on dont know the four deget number,can you help me get it off so my tv works again,,,please
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
I have onida tv, but child lock is enabled now it display only blue screen and demand enter your password.. but i dont know the password.. how i will solve it.. please tell me
The easiest way to resolve this is with the model number call the company who made it and they will have instructions on unlocking the set.
Mar 14, 2012 | Televison & Video
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
T.v. WE BOUGHT IS ON CHILD LOCK....
Maybe this will help you overcome those pesky child locks
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Good luck and let us know how this turns out for you.
Please rate my help++++Thanks for using FIXYA
May 06, 2010 | Jensen TS2750J TV
Child lock on rca r29sfoba
sometimes you can go through your tv menu to solve this problem... or you can get a advanced universal remote from walmart that has the parental button on it
Dec 12, 2008 | RCA F36645 TV
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
Help unlock child lock on tv.
my TV is show " child lock please unlock" and i repeatedly attempted and ther is no feasibility .
and i want help please help mee
Jun 06, 2008 | Philips Magnavox 27MS343S 27" TV
CHILD LOCK Help needed
Hello i recently had a problem that my tv just locked itself which i think is the same type of problem, i contacted Daewoo and they gave me the following code to try and it worked, not sure if it will do the same for your set, but it might be worth a try.
press the following buttons in the remote in sequence
BLUE
YELLOW
GREEN
RED
STANDBY TO TURN OFF
STANDBY TO TURN BACK ON.
Hope this might help, if not try contacting Daewoo Electronics website and put in your model number.
Regards
H wilson
Apr 12, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
27inch tv serial# 27r410T
Press vol-on tv& child lock on Remote together. Press mode on Remote using channel +/- to select child lock select new pin press mode E
Aug 08, 2007 | Sharp 25VS-J250 25" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
