Question about Dryers
Noisy GR gas dryer - Dryers
My dryer makes loud, high pitch sqeek, as if metal is rubbing.
Posted on Oct 27, 2008
We've got a noisy Maytag gas dryer and it has been suggested it needs brake shoes on the front and rollers on the back of the drum. Is anyone near enough to Oberon to assist us please?
To access the front you remove 2 screws at the base of the front and remove the front panel, newer models you pop the top first. Not all maytags are exactly the same. The front of the drum rides on plastic glides and the rear of the dryer rides on rollers. I made a few maytag dryer home videos HERE
Jul 23, 2012 | Maytag Dryers
My ge gas dryer squeeks its *** off
Helo there and welcome to fixya
This is a fairly common problem with these dryers
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 15, 2011 | Dryers
The dryer is making a knocking sound when running. The sound has increased lately. What may be the cause of the noise?
Hello there and thank you for choosing fixya
If your dryer is noisy, check these:
Aug 04, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Whirlpool Gas Dryer DBSR453 making grinding noise
http://www.repairclinic.com/Dryer-Troubleshooting
page down until its noisy, Good Luck Tim
Mar 05, 2011 | GE DBSR453GBWW Gas Dryer
Noisy and no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag PYE2300AY Electric Dryer
The dryer works perfectly but is very noisy can we have the technical diagram for the white knight gas tumble dryer please
The problem is likely the rear drum rollers. Here is a link that should help http://appliancehelponline.com/dryerrollervideo.html
You can also enter your model # there for diagrams and illustrations of your specific model.
Sep 16, 2010 | Crosley CDG6000 Gas Dryer
Glow igniter shuts down when dryer calls for gas
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Nov 14, 2009 | Whirlpool LGR4634J Gas Dryer
Noisy gas dryer, sounds like change in it. coins raddle arround
SOMETIMES COINS DO GET INSIDE THE BAFFLES. I HAD FOUND COINS IN THEM BEFORE
Apr 09, 2009 | Kenmore 73952 Gas Dryer
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
I have a noisy Maytag LDG 7500 gas dryer.
thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Dec 31, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
